1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Substitutions defaults and tricks
To: "Brown, Garth" <[email protected]>, "Pietryla, Anthony F." <[email protected]>
Date: Tue, 19 Nov 2013 10:42:58 -0800
> Hi Tony,
> In your example, there wouldn't be an option of whether you define TS1ST in st.cmd. You lose the default value so you must define it. The problem that I'm trying to solve is that there are literally hundreds of values with facility-specific defaults, not just TS1ST, and of those values most systems only need to define non-default values for a few of them if any.
Use include files with epicsEnvSet!
Example:
1/ FILE WITH DEFAULT VALUES
cat > all_my_default_valules.dft <<EOT
epicsEnvSet(SNOVA_DEVN, "SNOVA" )
epicsEnvSet(SNOVA_FSEP, "_" )
#And a lot more...
EOT
2/ FILE WITH DBLOAD
cat > database_load.dbl <<EOT
dbLoadRecords("${DB_DIR}/snova_asynStream.db","deviceName=${SNOVA_DEVN},_=${SNOVA_FSEP},asynPort=${SNOVAA_PORT},streamProtocol
=${SNOVAA_PROT}");
# And a lot more...
EOT
3/ IOC STARTUP FILE
cat > RunMe <<EOT
#!/usr/bin/env snova-3_14_11
< ${EPICS_IOCHOST}/envPaths                                                  # Path variables
dbLoadDatabase("${DBD_DIR}/snova.dbd")
snova_registerRecordDeviceDriver(pdbbase)
< ${DFT_DIR}/snova.dft
epicsEnvSet(SNOVA_DEVN, "SNOVA_1")                                      # First instance with non default name SNOVA_1
< ${DBL_DIR}/snova_streamEthernet.dbl
epicsEnvSet(SNOVA_DEVN, "SNOVA_2")                                      # Second instance with non default name SNOVA_2
iocInit()
EOT
Enjoy!
Emmanuel
RE: Substitutions defaults and tricks Emmanuel Mayssat
Substitutions defaults and tricks Brown, Garth
Re: Substitutions defaults and tricks Pietryla, Anthony F.
RE: Substitutions defaults and tricks Brown, Garth
Prev: RE: Convertion for asynFloat64 Mark Rivers
Next: RE: Substitutions defaults and tricks Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Substitutions defaults and tricks Michael Davidsaver
