1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to archive PVs in epics which are deployed in labview
To: [email protected]
Date: Thu, 21 Nov 2013 10:47:43 -0800
Himanshu
Depending on your specific requirements, and given your smallish number of PVs to archive, it may serve your purpose to simply use the camonitor commandline tool to collect PV monitors and redirect those to a file. It is possible to massage the output into a format more suitable for plotting or other post-processing fairly easily. I use a simple Perl script to do this quite often when monitoring PVs for my own diagnostics or development purposes.
This requires very little effort or resources, especially if this for a less formal or non-production setup, which it sounds like may be your situation.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
On 11/21/2013 01:56 AM, Himanshu Tyagi wrote:
Dear Emmanuel,
Thanks for your quick reply. We have around 30 PVs to be archived. We
have installed the utility you mentioned but we found that it requires
an active web access. Since we have our systems in local network we
can't keep it constantly connected to internet.
Can you please guide us how can we archive the PVs in locally connected
systems.
Himanshu
On Wed, Nov 20, 2013 at 12:40 AM, Emmanuel Mayssat <[email protected]
<mailto:[email protected]>> wrote:
    http://sourceforge.net/apps/trac/cs-studio/wiki/RDBArchive if you
    are already using CSS
    Otherwise, use my favourite:
    http://epicsarchiverap.sourceforge.net/quickstart.html
    The latter is used in production at SLAC and is still actively
    developed (contact Murali Shankar at mshankar AT slac DOT stanford
    DOT edu ).
    Additional to the online documentation, I can send you my
    installation note.
    How many PVs do you have on your 3 machines?
    Emmanuel
    Date: Tue, 19 Nov 2013 11:35:51 +0530
    Subject: How to archive PVs in epics which are deployed in labview
    To: [email protected] <mailto:[email protected]>;
    Hi all,
    We have a set up consisting of 3 machines, one labview RT acting as
    a epics server, one windows based labview PC and one epics based PC
    on RHEL 6.3.
    We have established communication between the 3 machines. The PVs
    deployed in RT could be displayed in CSS in epics PC. We wanted to
    archive these PVs in EPICS PC.
    Can anyone help us in this regard as to how can we archive these PVs?
    Himanshu
*Himanshu Tyagi*
Software Engineer Trainee
*fiserv*
Pune
*P** **Please consider the environment before printing this e-mail*
How to archive PVs in epics which are deployed in labview Himanshu Tyagi
RE: How to archive PVs in epics which are deployed in labview Emmanuel Mayssat
Re: How to archive PVs in epics which are deployed in labview Himanshu Tyagi
Prev: RE: areaDetector for a Basler GigE camera Mark Rivers
Next: Re: CSS EPICS PV connectivity issue Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How to archive PVs in epics which are deployed in labview Himanshu Tyagi
Next: Re: How to archive PVs in epics which are deployed in labview Pete Jemian
