1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: areaDetector for a Basler GigE camera
To: "'Florian Sorgenfrei'" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 21 Nov 2013 18:47:15 +0000
Sorry to immediately correct my own post.
A better way to compute the needed value of EPICS_CA_MAX_ARRAY_BYTES is from the waveform record you create for the NDStdArrays plugin.  You will compute the number of elements in that array as:
NELEMENTS = XPixels * YPixels * 3 (if color).
You will set the FTVL of that array depending on maximum bits/pixel you will be using: UCHAR for 8, SHORT for 12 or 16, etc.
EPICS_CA_MAX_ARRAY_BYTES should then be set to NELEMENTS * sizeof(FTVL type) + 16
As I recall the extra 16 bytes or so are needed on one side or the other.  I forget which side, so add a little extra on both sides.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: Thursday, November 21, 2013 12:40 PM
To: 'Florian Sorgenfrei'; [email protected]; [email protected]
> Is there a difference on linux between setenv EPICS_CA_MAX_ARRAY_BYTES 100000000
> in the terminal and in the startup script epicsEnvSet "EPICS_CA_MAX_ARRAY_BYTES",'100000000'?
I believe the startup script value will override the value the process inherited from the environment.
However, you should be careful with the actual value you use for EPICS_CA_MAX_ARRAY_BYTES.  My understanding is that the value is not simply a "maximum" value, it is the actual value that will be used for all CA buffers that need to be larger than the standard size of 16K.  You have set it to 100MB, which is probably much larger than it needs to be for the Basler camera.  You should set it just a little larger than the actual maximum value needed.  You can compute this for the Basler camera from XPixels * YPixels * max bytes/pixel * 3 (if color).
From: Florian Sorgenfrei [mailto:[email protected]]
Sent: Thursday, November 21, 2013 12:11 PM
To: Mark Rivers; [email protected]; [email protected]
Subject: Re: areaDetector for a Basler GigE camera
Ok, problem solved. Indeed setting environment variables was the point.
I just had to figure out how to do that in osx. Is there a difference on
linux between setenv EPICS_CA_MAX_ARRAY_BYTES 100000000 in the terminal
'100000000'? Anyway I now implemented the second option also and it
works happily.
Cheers,
Flo
Am 21.11.13 15:37, schrieb Mark Rivers:
> If you are using the ImageJ viewer plugin from areaDetector 1-9 or later then you should not use the JCALibrary.properties file, you should use the normal EPICS environment variable EPICS_CA_MAX_ARRAY_BYTES.  This needs to be set in both the IOC server process and the ImageJ client process.  The symptom you describe of being able to connect to the PVs but getting pendIO timeout exceptions is what is expected if EPICS_CA_MAX_ARRAY_BYTES is not set correctly on one end or the other.
> What happens if on the machine running ImageJ you use the "caget" command from EPICS base to read the ArrayData PV?  Does it succeed?
> Mark
Florian Sorgenfrei
Institute for Methods and Instrumentation for Synchrotron Radiation
Research G-ISRR
Albert-Einstein-Str. 15
D-12489 Berlin
GERMANY
Tel.: +49 30 8062 12924
Fax: +49 30 8062 14987
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
areaDetector for a Basler GigE camera Sorgenfrei, Florian
RE: areaDetector for a Basler GigE camera Mark Rivers
Re: areaDetector for a Basler GigE camera Florian Sorgenfrei
RE: areaDetector for a Basler GigE camera tom.cobb
Prev: RE: areaDetector for a Basler GigE camera Mark Rivers
Next: Re: How to archive PVs in epics which are deployed in labview Rod Nussbaumer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: areaDetector for a Basler GigE camera tom.cobb
