1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: areaDetector for a Basler GigE camera
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 21 Nov 2013 19:11:08 +0100
Ok, problem solved. Indeed setting environment variables was the point.
I just had to figure out how to do that in osx. Is there a difference on
linux between setenv EPICS_CA_MAX_ARRAY_BYTES 100000000 in the terminal
and in the startup script epicsEnvSet "EPICS_CA_MAX_ARRAY_BYTES",
'100000000'? Anyway I now implemented the second option also and it
works happily.
Cheers,
Flo
Am 21.11.13 15:37, schrieb Mark Rivers:
> If you are using the ImageJ viewer plugin from areaDetector 1-9 or later then you should not use the JCALibrary.properties file, you should use the normal EPICS environment variable EPICS_CA_MAX_ARRAY_BYTES.  This needs to be set in both the IOC server process and the ImageJ client process.  The symptom you describe of being able to connect to the PVs but getting pendIO timeout exceptions is what is expected if EPICS_CA_MAX_ARRAY_BYTES is not set correctly on one end or the other.
> What happens if on the machine running ImageJ you use the "caget" command from EPICS base to read the ArrayData PV?  Does it succeed?
> Mark
Florian Sorgenfrei
Institute for Methods and Instrumentation for Synchrotron Radiation
Research G-ISRR
Albert-Einstein-Str. 15
D-12489 Berlin
GERMANY
Tel.: +49 30 8062 12924
Fax: +49 30 8062 14987
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
RE: areaDetector for a Basler GigE camera Mark Rivers
areaDetector for a Basler GigE camera Sorgenfrei, Florian
Re: areaDetector for a Basler GigE camera Florian Sorgenfrei
RE: areaDetector for a Basler GigE camera tom.cobb
Prev: RE: areaDetector for a Basler GigE camera Mark Rivers
Next: CSS EPICS PV connectivity issue Juan Manuel Lozano
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: areaDetector for a Basler GigE camera Mark Rivers
