1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: areaDetector for a Basler GigE camera
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Wed, 20 Nov 2013 08:56:53 +0000
Hi Florian,
Once you have tried Mark's suggestions below, start the camera acquiring and check ARAVISCAM1:CAM:ArrayCounter_RBV to see if any arrays are being produced by the driver. If it doesn't increase then the problem is in the driver, otherwise the problem is in the plugin chain.
As to your startup script problems, I suspect you may still be loading the AVT_Manta_1_44_4.template file in your substitution file. Have you run the aravisGigEApp/src/makeDbAndEdl.py script to make a database and screen for your particular camera? If so, then you need to point the substitution file at the database template that this script created.
Tom Cobb
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: 19 November 2013 21:29
> To: 'Florian Sorgenfrei'; [email protected]
> Cc: Cobb, Tom (DLSLtd,RAL,TEC)
> Assuming the driver is actually talking to the camera and getting
> images then there are 2 common reasons that ARAVISCAM1:ARR:ArrayData
> would have all zeros:
> Make sure that the driver PV ArrayCallbacks is set to Enable.
> Make sure the NDStdArrays plugin has the EnableCallbacks PV set to Yes.
> These and other tips are contained in the areaDetector
> "Troubleshooting" documentation:
> http://cars9.uchicago.edu/software/epics/areaDetectorViewers.html#Troub
> leshooting
> I don't know why you are getting all the errors about the unknown
> Aravis parameters, perhaps Tom Cobb who wrote the driver can help.
> Mark
> From: Florian Sorgenfrei [mailto:florian.sorgenfrei@helmholtz-
> berlin.de]
> Sent: Tuesday, November 19, 2013 2:50 PM
> To: Mark Rivers; [email protected]
> Subject: Re: areaDetector for a Basler GigE camera
> Hi Mark,
> I managed to get through the compiling process. I can start the ioc and
> it connects to the camera. However, I get the (more or less) the same
> errors as Zenon Szalata got in 2011 (see techtalk and below). Moreover
> connecting (using ImageJ) to ARAVISCAM1:ARR: gives me a framerate of
> 0Hz. Reading ARAVISCAM1:ARR:ArrayData gives me only zeros.
> Funnily, I'm able to change for example the trigger mode of my camera
> using the ioc as you can see also below (the camera is attached to a
> hardware trigger with 50Hz).
> Any ideas?
> Cheers Flo
> xxx@yyy:~/devel/aravisGigE-0-1-15dls6/vendor/aravis-linux-x86_64/tests$
> ./arv-camera-test -n Basler-20804132
> Looking for camera 'Basler-20804132'
> vendor name         = Basler
> model name          = scA640-74gm
> device id           = 20804132
> image width         = 659
> image height        = 494
> horizontal binning  = 1
> vertical binning    = 1
> exposure            = 900 µs
> gain                = 280 dB
> Frame rate = 109 Hz
> Frame rate = 79 Hz
> Frame rate = 79 Hz
> Frame rate = 80 Hz
> Frame rate = 79 Hz
> Frame rate = 79 Hz
> Frame rate = 79 Hz
> Frame rate = 79 Hz
> Frame rate = 79 Hz
> Frame rate = 79 Hz
> Frame rate = 79 Hz
> Frame rate = 79 Hz
> Frame rate = 79 Hz
> Frame rate = 79 Hz
> ^CFrame rate = 79 Hz
> Completed buffers = 1216
> Failures          = 0
> Underruns         = 0
> 2013/11/19 21:06:30.433 asynPortDriver:drvUserCreate: addr=0, cannot
> find parameter SyncInLevels
> -bash: 2013/11/19: Datei oder Verzeichnis nicht gefunden
> caput ARAVISCAM1:CAM1:TriggerMode 1Channel connect timed out:
> 'ARAVISCAM1:CAM1:TriggerMode' not found.
> caput ARAVISCAM1:CAM:TriggerMode 1
> Old : ARAVISCAM1:CAM:TriggerMode     Off
> New : ARAVISCAM1:CAM:TriggerMode     On
> image width         = 659
> image height        = 494
> exposure            = 900 µs
> gain                = 280 dB
> Frame rate = 81 Hz
> Frame rate = 50 Hz
> Frame rate = 50 Hz
> Frame rate = 50 Hz
> Frame rate = 50 Hz
> Frame rate = 50 Hz
> Frame rate = 50 Hz
> ^CFrame rate = 50 Hz
> Completed buffers = 431
> Failures          = 0
> Underruns         = 0
> xxx@yyy:~/devel/aravisGigE-0-1-15dls6/iocs/example/bin/linux-x86_64$
> ./example stexample.boot
> # This file was automatically generated on Wed 12 Jun 2013 15:29:41 BST
> from
> # source:
> /dls_sw/prod/R3.14.11/support/aravisGigE/0-1-
> 15dls6/etc/makeIocs/example.xml
> # *** Please do not edit this file: edit the source file instead. ***
> #cd "/dls_sw/prod/R3.14.11/support/aravisGigE/0-1-15dls6/iocs/example"
> epicsEnvSet "EPICS_TS_MIN_WEST", '0'
> # Loading libraries
> # Device initialisation
> dbLoadDatabase "../../dbd/example.dbd"
> example_registerRecordDeviceDriver(pdbbase)
> # aravisCameraConfig(portName, cameraName, maxBuffers, maxMemory)
> aravisCameraConfig("CAM1", "Basler-20804132", 50, -1)
> Looking for camera 'Basler-20804132'...
> Your tick frequency is 125000000
> So your timestamp resolution is 8.000000 ns
> Done.
> Getting feature list...
> Done.
> pthread_attr_setstacksize error Invalid argument
> # NDStdArraysConfigure(portName, queueSize, blockingCallbacks,
> NDArrayPort, NDArrayAddr, maxMemory)
> NDStdArraysConfigure("ARR1", 2, 0, "CAM1", 0, 0)
> # Final ioc initialisation
> dbLoadRecords ("../../db/example_expanded.db","PORT=ARR1")
> iocInit
> Starting iocInit
> ## EPICS R3.14.12.3-6 $Date: Mon 2012-12-17 14:11:47 -0600$
> ## EPICS Base built May 22 2013
> 2013/11/19 21:06:30.427 asynPortDriver:drvUserCreate: addr=0, cannot
> find parameter AcquisitionFrameRateLimit
> ARAVISCAM1:CAM:AcquisitionFram1_RBV devAsynFloat64::initCommon
> drvUserCreate
> find parameter BlackLevel
> ARAVISCAM1:CAM:BlackLevel_RBV devAsynFloat64::initCommon drvUserCreate
> find parameter ColorTransformationValue
> ARAVISCAM1:CAM:ColorTransforma4_RBV devAsynFloat64::initCommon
> drvUserCreate
> 2013/11/19 21:06:30.428 asynPortDriver:drvUserCreate: addr=0, cannot
> find parameter GainAutoMax
> ARAVISCAM1:CAM:GainAutoMax_RBV devAsynFloat64::initCommon drvUserCreate
> find parameter GainAutoMin
> ARAVISCAM1:CAM:GainAutoMin_RBV devAsynFloat64::initCommon drvUserCreate
> find parameter Hue
> ARAVISCAM1:CAM:Hue_RBV devAsynFloat64::initCommon drvUserCreate
> find parameter Saturation
> ARAVISCAM1:CAM:Saturation_RBV devAsynFloat64::initCommon drvUserCreate
> find parameter TriggerDelayAbs
> ARAVISCAM1:CAM:TriggerDelayAbs_RBV devAsynFloat64::initCommon
> drvUserCreate
> ARAVISCAM1:CAM:AcquisitionFram1 devAsynFloat64::initCommon
> drvUserCreate
> ARAVISCAM1:CAM:BlackLevel devAsynFloat64::initCommon drvUserCreate
> ARAVISCAM1:CAM:ColorTransforma4 devAsynFloat64::initCommon
> drvUserCreate
> ARAVISCAM1:CAM:GainAutoMax devAsynFloat64::initCommon drvUserCreate
> ARAVISCAM1:CAM:GainAutoMin devAsynFloat64::initCommon drvUserCreate
> find parameter Hue
> ARAVISCAM1:CAM:Hue devAsynFloat64::initCommon drvUserCreate
> ARAVISCAM1:CAM:Saturation devAsynFloat64::initCommon drvUserCreate
> 2013/11/19 21:06:30.429 asynPortDriver:drvUserCreate: addr=0, cannot
> ARAVISCAM1:CAM:TriggerDelayAbs devAsynFloat64::initCommon drvUserCreate
> find parameter StreamFrameRateConstrain
> ARAVISCAM1:CAM:StreamFrameRateC_RBV devAsynInt32::initCommon
> drvUserCreate
> ARAVISCAM1:CAM:StreamFrameRateC devAsynInt32::initCommon drvUserCreate
> find parameter AcquisitionFrameCount
> ARAVISCAM1:CAM:AcquisitionFrame_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter BalanceWhiteAutoRate
> ARAVISCAM1:CAM:BalanceWhiteAut1_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter BalanceWhiteAutoAdjustTol
> ARAVISCAM1:CAM:BalanceWhiteAut2_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter DSPSubregionBottom
> ARAVISCAM1:CAM:DSPSubregionBott_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter DSPSubregionLeft
> ARAVISCAM1:CAM:DSPSubregionLeft_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter DSPSubregionRight
> ARAVISCAM1:CAM:DSPSubregionRigh_RBV devAsynInt32::initCommon
> drvUserCreate
> 2013/11/19 21:06:30.430 asynPortDriver:drvUserCreate: addr=0, cannot
> find parameter DSPSubregionTop
> ARAVISCAM1:CAM:DSPSubregionTop_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter DecimationHorizontal
> ARAVISCAM1:CAM:DecimationHorizo_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter DecimationVertical
> ARAVISCAM1:CAM:DecimationVertic_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter EventAcquisitionEnd
> ARAVISCAM1:CAM:EventAcquisitio0_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter EventAcquisitionRecordTrigger
> ARAVISCAM1:CAM:EventAcquisitio1_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter EventAcquisitionStart
> ARAVISCAM1:CAM:EventAcquisition_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter EventError
> ARAVISCAM1:CAM:EventError_RBV devAsynInt32::initCommon drvUserCreate
> find parameter EventExposureEnd
> ARAVISCAM1:CAM:EventExposureEnd_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter EventFrameTrigger
> ARAVISCAM1:CAM:EventFrameTrigge_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter EventLine1FallingEdge
> ARAVISCAM1:CAM:EventLine1Fallin_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter EventLine1RisingEdge
> ARAVISCAM1:CAM:EventLine1Rising_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter EventLine2FallingEdge
> ARAVISCAM1:CAM:EventLine2Fallin_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter EventLine2RisingEdge
> ARAVISCAM1:CAM:EventLine2Rising_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter EventLine3FallingEdge
> ARAVISCAM1:CAM:EventLine3Fallin_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter EventLine3RisingEdge
> ARAVISCAM1:CAM:EventLine3Rising_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter EventLine4FallingEdge
> ARAVISCAM1:CAM:EventLine4Fallin_RBV devAsynInt32::initCommon
> drvUserCreate
> 2013/11/19 21:06:30.431 asynPortDriver:drvUserCreate: addr=0, cannot
> find parameter EventLine4RisingEdge
> ARAVISCAM1:CAM:EventLine4Rising_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter EventOverflow
> ARAVISCAM1:CAM:EventOverflow_RBV devAsynInt32::initCommon drvUserCreate
> find parameter EventsEnable1
> ARAVISCAM1:CAM:EventsEnable1_RBV devAsynInt32::initCommon drvUserCreate
> find parameter ExposureAutoAdjustTol
> ARAVISCAM1:CAM:ExposureAutoAdju_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter ExposureAutoMax
> ARAVISCAM1:CAM:ExposureAutoMax_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter ExposureAutoMin
> ARAVISCAM1:CAM:ExposureAutoMin_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter ExposureAutoOutliers
> ARAVISCAM1:CAM:ExposureAutoOutl_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter ExposureAutoRate
> ARAVISCAM1:CAM:ExposureAutoRate_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter ExposureAutoTarget
> ARAVISCAM1:CAM:ExposureAutoTarg_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter ExposureValue
> ARAVISCAM1:CAM:ExposureValue_RBV devAsynInt32::initCommon drvUserCreate
> find parameter FirmwareVerBuild
> ARAVISCAM1:CAM:FirmwareVerBuild_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter FirmwareVerMajor
> ARAVISCAM1:CAM:FirmwareVerMajor_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter FirmwareVerMinor
> ARAVISCAM1:CAM:FirmwareVerMinor_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter FrameStartTriggerDelay
> ARAVISCAM1:CAM:FrameStartTrigge_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter GainAutoAdjustTol
> ARAVISCAM1:CAM:GainAutoAdjustTo_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter GainAutoOutliers
> ARAVISCAM1:CAM:GainAutoOutliers_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter GainAutoRate
> ARAVISCAM1:CAM:GainAutoRate_RBV devAsynInt32::initCommon drvUserCreate
> 2013/11/19 21:06:30.432 asynPortDriver:drvUserCreate: addr=0, cannot
> find parameter GainAutoTarget
> ARAVISCAM1:CAM:GainAutoTarget_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter GainValue
> ARAVISCAM1:CAM:GainValue_RBV devAsynInt32::initCommon drvUserCreate
> find parameter ImageSize
> ARAVISCAM1:CAM:ImageSize_RBV devAsynInt32::initCommon drvUserCreate
> find parameter IrisAutoTarget
> ARAVISCAM1:CAM:IrisAutoTarget_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter IrisVideoLevelMax
> ARAVISCAM1:CAM:IrisVideoLevelMa_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter IrisVideoLevelMin
> ARAVISCAM1:CAM:IrisVideoLevelMi_RBV devAsynInt32::initCommon
> drvUserCreate
> ARAVISCAM1:CAM:IrisVideoLevel_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter LUTAddress
> ARAVISCAM1:CAM:LUTAddress_RBV devAsynInt32::initCommon drvUserCreate
> find parameter LUTBitDepthIn
> ARAVISCAM1:CAM:LUTBitDepthIn_RBV devAsynInt32::initCommon drvUserCreate
> find parameter LUTBitDepthOut
> ARAVISCAM1:CAM:LUTBitDepthOut_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter LUTSizeBytes
> ARAVISCAM1:CAM:LUTSizeBytes_RBV devAsynInt32::initCommon drvUserCreate
> find parameter LensDriveDuration
> ARAVISCAM1:CAM:LensDriveDuratio_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter LensVoltageControl
> ARAVISCAM1:CAM:LensVoltageContr_RBV devAsynInt32::initCommon
> drvUserCreate
> ARAVISCAM1:CAM:LensVoltage_RBV devAsynInt32::initCommon drvUserCreate
> find parameter NonImagePayloadSize
> ARAVISCAM1:CAM:NonImagePayloadS_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter OffsetValue
> ARAVISCAM1:CAM:OffsetValue_RBV devAsynInt32::initCommon drvUserCreate
> find parameter PvGainAutoMax
> ARAVISCAM1:CAM:PvGainAutoMax_RBV devAsynInt32::initCommon drvUserCreate
> find parameter PvGainAutoMin
> ARAVISCAM1:CAM:PvGainAutoMin_RBV devAsynInt32::initCommon drvUserCreate
> find parameter RecorderPreEventCount
> ARAVISCAM1:CAM:RecorderPreEvent_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter SensorBits
> ARAVISCAM1:CAM:SensorBits_RBV devAsynInt32::initCommon drvUserCreate
> find parameter StreamBytesPerSecond
> ARAVISCAM1:CAM:StreamBytesPerSe_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter StreamHoldCapacity
> ARAVISCAM1:CAM:StreamHoldCapaci_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter StrobeDelay
> ARAVISCAM1:CAM:StrobeDelay_RBV devAsynInt32::initCommon drvUserCreate
> find parameter StrobeDuration
> ARAVISCAM1:CAM:StrobeDuration_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter SyncInGlitchFilter
> ARAVISCAM1:CAM:SyncInGlitchFilt_RBV devAsynInt32::initCommon
> drvUserCreate
> ARAVISCAM1:CAM:SyncInLevels_RBV devAsynInt32::initCommon drvUserCreate
> find parameter SyncOutLevels
> ARAVISCAM1:CAM:SyncOutLevels_RBV devAsynInt32::initCommon drvUserCreate
> find parameter TimeStampValueHi
> ARAVISCAM1:CAM:TimeStampValueHi_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter TimeStampValueLo
> ARAVISCAM1:CAM:TimeStampValueLo_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter VsubValue
> ARAVISCAM1:CAM:VsubValue_RBV devAsynInt32::initCommon drvUserCreate
> find parameter WhitebalValueBlue
> ARAVISCAM1:CAM:WhitebalValueBlu_RBV devAsynInt32::initCommon
> drvUserCreate
> 2013/11/19 21:06:30.434 asynPortDriver:drvUserCreate: addr=0, cannot
> find parameter WhitebalValueRed
> ARAVISCAM1:CAM:WhitebalValueRed_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter AcquisitionAbort
> ARAVISCAM1:CAM:AcquisitionAbort devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:AcquisitionFrame devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:BalanceWhiteAut1 devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:BalanceWhiteAut2 devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:DSPSubregionBott devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:DSPSubregionLeft devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:DSPSubregionRigh devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:DSPSubregionTop devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:DecimationHorizo devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:DecimationVertic devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:EventAcquisitio0 devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:EventAcquisitio1 devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:EventAcquisition devAsynInt32::initCommon drvUserCreate
> 2013/11/19 21:06:30.435 asynPortDriver:drvUserCreate: addr=0, cannot
> ARAVISCAM1:CAM:EventError devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:EventExposureEnd devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:EventFrameTrigge devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:EventLine1Fallin devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:EventLine1Rising devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:EventLine2Fallin devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:EventLine2Rising devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:EventLine3Fallin devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:EventLine3Rising devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:EventLine4Fallin devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:EventLine4Rising devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:EventOverflow devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:EventsEnable1 devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:ExposureAutoAdju devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:ExposureAutoMax devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:ExposureAutoMin devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:ExposureAutoOutl devAsynInt32::initCommon drvUserCreate
> 2013/11/19 21:06:30.436 asynPortDriver:drvUserCreate: addr=0, cannot
> ARAVISCAM1:CAM:ExposureAutoRate devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:ExposureAutoTarg devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:ExposureValue devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:FirmwareVerBuild devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:FirmwareVerMajor devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:FirmwareVerMinor devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:FrameStartTrigge devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:GainAutoAdjustTo devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:GainAutoOutliers devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:GainAutoRate devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:GainAutoTarget devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:GainValue devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:ImageSize devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:IrisAutoTarget devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:IrisVideoLevel devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:IrisVideoLevelMa devAsynInt32::initCommon drvUserCreate
> 2013/11/19 21:06:30.437 asynPortDriver:drvUserCreate: addr=0, cannot
> ARAVISCAM1:CAM:IrisVideoLevelMi devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:LUTAddress devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:LUTBitDepthIn devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:LUTBitDepthOut devAsynInt32::initCommon drvUserCreate
> find parameter LUTLoad
> ARAVISCAM1:CAM:LUTLoad devAsynInt32::initCommon drvUserCreate
> find parameter LUTSave
> ARAVISCAM1:CAM:LUTSave devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:LUTSizeBytes devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:LensDriveDuratio devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:LensVoltage devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:LensVoltageContr devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:NonImagePayloadS devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:OffsetValue devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:PvGainAutoMax devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:PvGainAutoMin devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:RecorderPreEvent devAsynInt32::initCommon drvUserCreate
> 2013/11/19 21:06:30.438 asynPortDriver:drvUserCreate: addr=0, cannot
> ARAVISCAM1:CAM:SensorBits devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:StreamBytesPerSe devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:StreamHoldCapaci devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:StrobeDelay devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:StrobeDuration devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:SyncInGlitchFilt devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:SyncInLevels devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:SyncOutLevels devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:TimeStampValueHi devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:TimeStampValueLo devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:VsubValue devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:WhitebalValueBlu devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:WhitebalValueRed devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:BalanceWhiteAut0_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter BandwidthControlMode
> ARAVISCAM1:CAM:BandwidthControl_RBV devAsynInt32::initCommon
> drvUserCreate
> 2013/11/19 21:06:30.439 asynPortDriver:drvUserCreate: addr=0, cannot
> find parameter ColorTransformationSelector
> ARAVISCAM1:CAM:ColorTransforma0_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter ColorTransformationMode
> ARAVISCAM1:CAM:ColorTransforma1_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter ColorTransformationValueSelector
> ARAVISCAM1:CAM:ColorTransforma2_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter DefectMaskColumnEnable
> ARAVISCAM1:CAM:DefectMaskColumn_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter DefectMaskPixelEnable
> ARAVISCAM1:CAM:DefectMaskPixelE_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter EdgeFilter
> ARAVISCAM1:CAM:EdgeFilter_RBV devAsynInt32::initCommon drvUserCreate
> find parameter ExposureAutoAlg
> ARAVISCAM1:CAM:ExposureAutoAlg_RBV devAsynInt32::initCommon
> drvUserCreate
> ARAVISCAM1:CAM:ExposureAuto_RBV devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:GainAuto_RBV devAsynInt32::initCommon drvUserCreate
> 2013/11/19 21:06:30.440 asynPortDriver:drvUserCreate: addr=0, cannot
> find parameter IrisMode
> ARAVISCAM1:CAM:IrisMode_RBV devAsynInt32::initCommon drvUserCreate
> find parameter LUTMode
> ARAVISCAM1:CAM:LUTMode_RBV devAsynInt32::initCommon drvUserCreate
> find parameter LensDriveCommand
> ARAVISCAM1:CAM:LensDriveCommand_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter PvDummyFrameStartTriggerMode
> ARAVISCAM1:CAM:PvDummyFrameStar_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter PvDummyTriggerMode
> ARAVISCAM1:CAM:PvDummyTriggerMo_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter PvDummyTriggerSelector
> ARAVISCAM1:CAM:PvDummyTriggerSe_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter SensorType
> ARAVISCAM1:CAM:SensorType_RBV devAsynInt32::initCommon drvUserCreate
> 2013/11/19 21:06:30.441 asynPortDriver:drvUserCreate: addr=0, cannot
> find parameter StreamHoldEnable
> ARAVISCAM1:CAM:StreamHoldEnable_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter StrobeDurationMode
> ARAVISCAM1:CAM:StrobeDurationMo_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter StrobeSource
> ARAVISCAM1:CAM:StrobeSource_RBV devAsynInt32::initCommon drvUserCreate
> find parameter SyncInSelector
> ARAVISCAM1:CAM:SyncInSelector_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter SyncOutPolarity
> ARAVISCAM1:CAM:SyncOutPolarity_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter SyncOutSelector
> ARAVISCAM1:CAM:SyncOutSelector_RBV devAsynInt32::initCommon
> drvUserCreate
> find parameter SyncOutSource
> ARAVISCAM1:CAM:SyncOutSource_RBV devAsynInt32::initCommon drvUserCreate
> find parameter TriggerOverlap
> ARAVISCAM1:CAM:TriggerOverlap_RBV devAsynInt32::initCommon
> drvUserCreate
> ARAVISCAM1:CAM:BalanceWhiteAut0 devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:BandwidthControl devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:ColorTransforma0 devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:ColorTransforma1 devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:ColorTransforma2 devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:DefectMaskColumn devAsynInt32::initCommon drvUserCreate
> 2013/11/19 21:06:30.442 asynPortDriver:drvUserCreate: addr=0, cannot
> ARAVISCAM1:CAM:DefectMaskPixelE devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:EdgeFilter devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:ExposureAuto devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:ExposureAutoAlg devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:GainAuto devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:IrisMode devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:LUTMode devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:LensDriveCommand devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:PvDummyFrameStar devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:PvDummyTriggerMo devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:PvDummyTriggerSe devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:SensorType devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:StreamHoldEnable devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:StrobeDurationMo devAsynInt32::initCommon drvUserCreate
> 2013/11/19 21:06:30.443 asynPortDriver:drvUserCreate: addr=0, cannot
> ARAVISCAM1:CAM:StrobeSource devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:SyncInSelector devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:SyncOutPolarity devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:SyncOutSelector devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:SyncOutSource devAsynInt32::initCommon drvUserCreate
> ARAVISCAM1:CAM:TriggerOverlap devAsynInt32::initCommon drvUserCreate
> find parameter DevicePartNumber
> ARAVISCAM1:CAM:DevicePartNumber_RBV devAsynOctet drvUserCreate failed
> find parameter ModelName
> ARAVISCAM1:CAM:ModelName_RBV devAsynOctet drvUserCreate failed
> cas warning: Configured TCP port was unavailable.
> cas warning: Using dynamically assigned TCP port 38799,
> cas warning: but now two or more servers share the same UDP port.
> cas warning: Depending on your IP kernel this server may not be
> cas warning: reachable with UDP unicast (a host's IP in
> EPICS_CA_ADDR_LIST)
> iocRun: All initialization complete
> epics>
> Am 14.11.13 20:59, schrieb Mark Rivers:
> > Hi Florian,
> > I think the problem is simpler than you think.  Now that you have the
> complete version of areaDetector, you should be able to build and run
> the ararvis driver and example IOC.  Don't worry about the Prosilica
> application and example Prosilica IOC that is part of areaDetector.
> > The DLS aravis driver needs to find the areaDetector base and plugin
> libraries.  Once it finds those successfully then the aravis driver and
> example IOC in the DLS package should build successfully, and you
> should be able to control the Basler camera with that example IOC.
> > The only thing you should need to change is the
> aravis/configure/RELEASE file to point to the new version of
> areaDetector that you have installed and built.
> > Let me know if you have more questions or problems.
> > Mark
> Florian Sorgenfrei
> Institute for Methods and Instrumentation for Synchrotron Radiation
> Research G-ISRR
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Albert-Einstein-Str. 15
> D-12489 Berlin
> GERMANY
> Tel.: +49 30 8062 12924
> Fax: +49 30 8062 14987
> ________________________________
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
> Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch,
> stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
> Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas
> Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
Re: areaDetector for a Basler GigE camera Florian Sorgenfrei
areaDetector for a Basler GigE camera Sorgenfrei, Florian
RE: areaDetector for a Basler GigE camera Mark Rivers
Prev: RE: areaDetector for a Basler GigE camera Mark Rivers
Next: Re: Convertion for asynFloat64 Benoit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: areaDetector for a Basler GigE camera Florian Sorgenfrei
