1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: areaDetector for a Basler GigE camera
To: "'Florian Sorgenfrei'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 19 Nov 2013 21:28:39 +0000
Assuming the driver is actually talking to the camera and getting images then there are 2 common reasons that ARAVISCAM1:ARR:ArrayData would have all zeros:
Make sure that the driver PV ArrayCallbacks is set to Enable.
Make sure the NDStdArrays plugin has the EnableCallbacks PV set to Yes.
These and other tips are contained in the areaDetector "Troubleshooting" documentation:
http://cars9.uchicago.edu/software/epics/areaDetectorViewers.html#Troubleshooting
I don't know why you are getting all the errors about the unknown Aravis parameters, perhaps Tom Cobb who wrote the driver can help.
-----Original Message-----
From: Florian Sorgenfrei [mailto:[email protected]]
Sent: Tuesday, November 19, 2013 2:50 PM
To: Mark Rivers; [email protected]
Subject: Re: areaDetector for a Basler GigE camera
Hi Mark,
I managed to get through the compiling process. I can start the ioc and
it connects to the camera. However, I get the (more or less) the same
errors as Zenon Szalata got in 2011 (see techtalk and below). Moreover
connecting (using ImageJ) to ARAVISCAM1:ARR: gives me a framerate of
0Hz. Reading ARAVISCAM1:ARR:ArrayData gives me only zeros.
Funnily, I'm able to change for example the trigger mode of my camera
using the ioc as you can see also below (the camera is attached to a
hardware trigger with 50Hz).
Any ideas?
Cheers Flo
xxx@yyy:~/devel/aravisGigE-0-1-15dls6/vendor/aravis-linux-x86_64/tests$
./arv-camera-test -n Basler-20804132
Looking for camera 'Basler-20804132'
vendor name         = Basler
model name          = scA640-74gm
device id           = 20804132
image width         = 659
image height        = 494
horizontal binning  = 1
vertical binning    = 1
exposure            = 900 µs
gain                = 280 dB
Frame rate = 109 Hz
Frame rate = 79 Hz
Frame rate = 79 Hz
Frame rate = 80 Hz
Frame rate = 79 Hz
Frame rate = 79 Hz
Frame rate = 79 Hz
Frame rate = 79 Hz
Frame rate = 79 Hz
Frame rate = 79 Hz
Frame rate = 79 Hz
Frame rate = 79 Hz
Frame rate = 79 Hz
Frame rate = 79 Hz
^CFrame rate = 79 Hz
Completed buffers = 1216
Failures          = 0
Underruns         = 0
2013/11/19 21:06:30.433 asynPortDriver:drvUserCreate: addr=0, cannot
find parameter SyncInLevels
-bash: 2013/11/19: Datei oder Verzeichnis nicht gefunden
caput ARAVISCAM1:CAM1:TriggerMode 1Channel connect timed out:
'ARAVISCAM1:CAM1:TriggerMode' not found.
caput ARAVISCAM1:CAM:TriggerMode 1
Old : ARAVISCAM1:CAM:TriggerMode     Off
New : ARAVISCAM1:CAM:TriggerMode     On
image width         = 659
image height        = 494
exposure            = 900 µs
gain                = 280 dB
Frame rate = 81 Hz
Frame rate = 50 Hz
Frame rate = 50 Hz
Frame rate = 50 Hz
Frame rate = 50 Hz
Frame rate = 50 Hz
Frame rate = 50 Hz
^CFrame rate = 50 Hz
Completed buffers = 431
Failures          = 0
Underruns         = 0
xxx@yyy:~/devel/aravisGigE-0-1-15dls6/iocs/example/bin/linux-x86_64$
./example stexample.boot
# This file was automatically generated on Wed 12 Jun 2013 15:29:41 BST from
# source:
/dls_sw/prod/R3.14.11/support/aravisGigE/0-1-15dls6/etc/makeIocs/example.xml
# *** Please do not edit this file: edit the source file instead. ***
#cd "/dls_sw/prod/R3.14.11/support/aravisGigE/0-1-15dls6/iocs/example"
epicsEnvSet "EPICS_TS_MIN_WEST", '0'
# Loading libraries
# Device initialisation
dbLoadDatabase "../../dbd/example.dbd"
example_registerRecordDeviceDriver(pdbbase)
# aravisCameraConfig(portName, cameraName, maxBuffers, maxMemory)
aravisCameraConfig("CAM1", "Basler-20804132", 50, -1)
Looking for camera 'Basler-20804132'...
Your tick frequency is 125000000
So your timestamp resolution is 8.000000 ns
Done.
Getting feature list...
Done.
pthread_attr_setstacksize error Invalid argument
# NDStdArraysConfigure(portName, queueSize, blockingCallbacks,
NDArrayPort, NDArrayAddr, maxMemory)
NDStdArraysConfigure("ARR1", 2, 0, "CAM1", 0, 0)
# Final ioc initialisation
dbLoadRecords ("../../db/example_expanded.db","PORT=ARR1")
iocInit
Starting iocInit
## EPICS R3.14.12.3-6 $Date: Mon 2012-12-17 14:11:47 -0600$
## EPICS Base built May 22 2013
2013/11/19 21:06:30.427 asynPortDriver:drvUserCreate: addr=0, cannot
find parameter AcquisitionFrameRateLimit
ARAVISCAM1:CAM:AcquisitionFram1_RBV devAsynFloat64::initCommon
drvUserCreate
find parameter BlackLevel
ARAVISCAM1:CAM:BlackLevel_RBV devAsynFloat64::initCommon drvUserCreate
find parameter ColorTransformationValue
ARAVISCAM1:CAM:ColorTransforma4_RBV devAsynFloat64::initCommon
drvUserCreate
2013/11/19 21:06:30.428 asynPortDriver:drvUserCreate: addr=0, cannot
find parameter GainAutoMax
ARAVISCAM1:CAM:GainAutoMax_RBV devAsynFloat64::initCommon drvUserCreate
find parameter GainAutoMin
ARAVISCAM1:CAM:GainAutoMin_RBV devAsynFloat64::initCommon drvUserCreate
find parameter Hue
ARAVISCAM1:CAM:Hue_RBV devAsynFloat64::initCommon drvUserCreate
find parameter Saturation
ARAVISCAM1:CAM:Saturation_RBV devAsynFloat64::initCommon drvUserCreate
find parameter TriggerDelayAbs
ARAVISCAM1:CAM:TriggerDelayAbs_RBV devAsynFloat64::initCommon drvUserCreate
ARAVISCAM1:CAM:AcquisitionFram1 devAsynFloat64::initCommon drvUserCreate
ARAVISCAM1:CAM:BlackLevel devAsynFloat64::initCommon drvUserCreate
ARAVISCAM1:CAM:ColorTransforma4 devAsynFloat64::initCommon drvUserCreate
ARAVISCAM1:CAM:GainAutoMax devAsynFloat64::initCommon drvUserCreate
ARAVISCAM1:CAM:GainAutoMin devAsynFloat64::initCommon drvUserCreate
find parameter Hue
ARAVISCAM1:CAM:Hue devAsynFloat64::initCommon drvUserCreate
ARAVISCAM1:CAM:Saturation devAsynFloat64::initCommon drvUserCreate
2013/11/19 21:06:30.429 asynPortDriver:drvUserCreate: addr=0, cannot
ARAVISCAM1:CAM:TriggerDelayAbs devAsynFloat64::initCommon drvUserCreate
find parameter StreamFrameRateConstrain
ARAVISCAM1:CAM:StreamFrameRateC_RBV devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:StreamFrameRateC devAsynInt32::initCommon drvUserCreate
find parameter AcquisitionFrameCount
ARAVISCAM1:CAM:AcquisitionFrame_RBV devAsynInt32::initCommon drvUserCreate
find parameter BalanceWhiteAutoRate
ARAVISCAM1:CAM:BalanceWhiteAut1_RBV devAsynInt32::initCommon drvUserCreate
find parameter BalanceWhiteAutoAdjustTol
ARAVISCAM1:CAM:BalanceWhiteAut2_RBV devAsynInt32::initCommon drvUserCreate
find parameter DSPSubregionBottom
ARAVISCAM1:CAM:DSPSubregionBott_RBV devAsynInt32::initCommon drvUserCreate
find parameter DSPSubregionLeft
ARAVISCAM1:CAM:DSPSubregionLeft_RBV devAsynInt32::initCommon drvUserCreate
find parameter DSPSubregionRight
ARAVISCAM1:CAM:DSPSubregionRigh_RBV devAsynInt32::initCommon drvUserCreate
2013/11/19 21:06:30.430 asynPortDriver:drvUserCreate: addr=0, cannot
find parameter DSPSubregionTop
ARAVISCAM1:CAM:DSPSubregionTop_RBV devAsynInt32::initCommon drvUserCreate
find parameter DecimationHorizontal
ARAVISCAM1:CAM:DecimationHorizo_RBV devAsynInt32::initCommon drvUserCreate
find parameter DecimationVertical
ARAVISCAM1:CAM:DecimationVertic_RBV devAsynInt32::initCommon drvUserCreate
find parameter EventAcquisitionEnd
ARAVISCAM1:CAM:EventAcquisitio0_RBV devAsynInt32::initCommon drvUserCreate
find parameter EventAcquisitionRecordTrigger
ARAVISCAM1:CAM:EventAcquisitio1_RBV devAsynInt32::initCommon drvUserCreate
find parameter EventAcquisitionStart
ARAVISCAM1:CAM:EventAcquisition_RBV devAsynInt32::initCommon drvUserCreate
find parameter EventError
ARAVISCAM1:CAM:EventError_RBV devAsynInt32::initCommon drvUserCreate
find parameter EventExposureEnd
ARAVISCAM1:CAM:EventExposureEnd_RBV devAsynInt32::initCommon drvUserCreate
find parameter EventFrameTrigger
ARAVISCAM1:CAM:EventFrameTrigge_RBV devAsynInt32::initCommon drvUserCreate
find parameter EventLine1FallingEdge
ARAVISCAM1:CAM:EventLine1Fallin_RBV devAsynInt32::initCommon drvUserCreate
find parameter EventLine1RisingEdge
ARAVISCAM1:CAM:EventLine1Rising_RBV devAsynInt32::initCommon drvUserCreate
find parameter EventLine2FallingEdge
ARAVISCAM1:CAM:EventLine2Fallin_RBV devAsynInt32::initCommon drvUserCreate
find parameter EventLine2RisingEdge
ARAVISCAM1:CAM:EventLine2Rising_RBV devAsynInt32::initCommon drvUserCreate
find parameter EventLine3FallingEdge
ARAVISCAM1:CAM:EventLine3Fallin_RBV devAsynInt32::initCommon drvUserCreate
find parameter EventLine3RisingEdge
ARAVISCAM1:CAM:EventLine3Rising_RBV devAsynInt32::initCommon drvUserCreate
find parameter EventLine4FallingEdge
ARAVISCAM1:CAM:EventLine4Fallin_RBV devAsynInt32::initCommon drvUserCreate
2013/11/19 21:06:30.431 asynPortDriver:drvUserCreate: addr=0, cannot
find parameter EventLine4RisingEdge
ARAVISCAM1:CAM:EventLine4Rising_RBV devAsynInt32::initCommon drvUserCreate
find parameter EventOverflow
ARAVISCAM1:CAM:EventOverflow_RBV devAsynInt32::initCommon drvUserCreate
find parameter EventsEnable1
ARAVISCAM1:CAM:EventsEnable1_RBV devAsynInt32::initCommon drvUserCreate
find parameter ExposureAutoAdjustTol
ARAVISCAM1:CAM:ExposureAutoAdju_RBV devAsynInt32::initCommon drvUserCreate
find parameter ExposureAutoMax
ARAVISCAM1:CAM:ExposureAutoMax_RBV devAsynInt32::initCommon drvUserCreate
find parameter ExposureAutoMin
ARAVISCAM1:CAM:ExposureAutoMin_RBV devAsynInt32::initCommon drvUserCreate
find parameter ExposureAutoOutliers
ARAVISCAM1:CAM:ExposureAutoOutl_RBV devAsynInt32::initCommon drvUserCreate
find parameter ExposureAutoRate
ARAVISCAM1:CAM:ExposureAutoRate_RBV devAsynInt32::initCommon drvUserCreate
find parameter ExposureAutoTarget
ARAVISCAM1:CAM:ExposureAutoTarg_RBV devAsynInt32::initCommon drvUserCreate
find parameter ExposureValue
ARAVISCAM1:CAM:ExposureValue_RBV devAsynInt32::initCommon drvUserCreate
find parameter FirmwareVerBuild
ARAVISCAM1:CAM:FirmwareVerBuild_RBV devAsynInt32::initCommon drvUserCreate
find parameter FirmwareVerMajor
ARAVISCAM1:CAM:FirmwareVerMajor_RBV devAsynInt32::initCommon drvUserCreate
find parameter FirmwareVerMinor
ARAVISCAM1:CAM:FirmwareVerMinor_RBV devAsynInt32::initCommon drvUserCreate
find parameter FrameStartTriggerDelay
ARAVISCAM1:CAM:FrameStartTrigge_RBV devAsynInt32::initCommon drvUserCreate
find parameter GainAutoAdjustTol
ARAVISCAM1:CAM:GainAutoAdjustTo_RBV devAsynInt32::initCommon drvUserCreate
find parameter GainAutoOutliers
ARAVISCAM1:CAM:GainAutoOutliers_RBV devAsynInt32::initCommon drvUserCreate
find parameter GainAutoRate
ARAVISCAM1:CAM:GainAutoRate_RBV devAsynInt32::initCommon drvUserCreate
2013/11/19 21:06:30.432 asynPortDriver:drvUserCreate: addr=0, cannot
find parameter GainAutoTarget
ARAVISCAM1:CAM:GainAutoTarget_RBV devAsynInt32::initCommon drvUserCreate
find parameter GainValue
ARAVISCAM1:CAM:GainValue_RBV devAsynInt32::initCommon drvUserCreate
find parameter ImageSize
ARAVISCAM1:CAM:ImageSize_RBV devAsynInt32::initCommon drvUserCreate
find parameter IrisAutoTarget
ARAVISCAM1:CAM:IrisAutoTarget_RBV devAsynInt32::initCommon drvUserCreate
find parameter IrisVideoLevelMax
ARAVISCAM1:CAM:IrisVideoLevelMa_RBV devAsynInt32::initCommon drvUserCreate
find parameter IrisVideoLevelMin
ARAVISCAM1:CAM:IrisVideoLevelMi_RBV devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:IrisVideoLevel_RBV devAsynInt32::initCommon drvUserCreate
find parameter LUTAddress
ARAVISCAM1:CAM:LUTAddress_RBV devAsynInt32::initCommon drvUserCreate
find parameter LUTBitDepthIn
ARAVISCAM1:CAM:LUTBitDepthIn_RBV devAsynInt32::initCommon drvUserCreate
find parameter LUTBitDepthOut
ARAVISCAM1:CAM:LUTBitDepthOut_RBV devAsynInt32::initCommon drvUserCreate
find parameter LUTSizeBytes
ARAVISCAM1:CAM:LUTSizeBytes_RBV devAsynInt32::initCommon drvUserCreate
find parameter LensDriveDuration
ARAVISCAM1:CAM:LensDriveDuratio_RBV devAsynInt32::initCommon drvUserCreate
find parameter LensVoltageControl
ARAVISCAM1:CAM:LensVoltageContr_RBV devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:LensVoltage_RBV devAsynInt32::initCommon drvUserCreate
find parameter NonImagePayloadSize
ARAVISCAM1:CAM:NonImagePayloadS_RBV devAsynInt32::initCommon drvUserCreate
find parameter OffsetValue
ARAVISCAM1:CAM:OffsetValue_RBV devAsynInt32::initCommon drvUserCreate
find parameter PvGainAutoMax
ARAVISCAM1:CAM:PvGainAutoMax_RBV devAsynInt32::initCommon drvUserCreate
find parameter PvGainAutoMin
ARAVISCAM1:CAM:PvGainAutoMin_RBV devAsynInt32::initCommon drvUserCreate
find parameter RecorderPreEventCount
ARAVISCAM1:CAM:RecorderPreEvent_RBV devAsynInt32::initCommon drvUserCreate
find parameter SensorBits
ARAVISCAM1:CAM:SensorBits_RBV devAsynInt32::initCommon drvUserCreate
find parameter StreamBytesPerSecond
ARAVISCAM1:CAM:StreamBytesPerSe_RBV devAsynInt32::initCommon drvUserCreate
find parameter StreamHoldCapacity
ARAVISCAM1:CAM:StreamHoldCapaci_RBV devAsynInt32::initCommon drvUserCreate
find parameter StrobeDelay
ARAVISCAM1:CAM:StrobeDelay_RBV devAsynInt32::initCommon drvUserCreate
find parameter StrobeDuration
ARAVISCAM1:CAM:StrobeDuration_RBV devAsynInt32::initCommon drvUserCreate
find parameter SyncInGlitchFilter
ARAVISCAM1:CAM:SyncInGlitchFilt_RBV devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:SyncInLevels_RBV devAsynInt32::initCommon drvUserCreate
find parameter SyncOutLevels
ARAVISCAM1:CAM:SyncOutLevels_RBV devAsynInt32::initCommon drvUserCreate
find parameter TimeStampValueHi
ARAVISCAM1:CAM:TimeStampValueHi_RBV devAsynInt32::initCommon drvUserCreate
find parameter TimeStampValueLo
ARAVISCAM1:CAM:TimeStampValueLo_RBV devAsynInt32::initCommon drvUserCreate
find parameter VsubValue
ARAVISCAM1:CAM:VsubValue_RBV devAsynInt32::initCommon drvUserCreate
find parameter WhitebalValueBlue
ARAVISCAM1:CAM:WhitebalValueBlu_RBV devAsynInt32::initCommon drvUserCreate
2013/11/19 21:06:30.434 asynPortDriver:drvUserCreate: addr=0, cannot
find parameter WhitebalValueRed
ARAVISCAM1:CAM:WhitebalValueRed_RBV devAsynInt32::initCommon drvUserCreate
find parameter AcquisitionAbort
ARAVISCAM1:CAM:AcquisitionAbort devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:AcquisitionFrame devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:BalanceWhiteAut1 devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:BalanceWhiteAut2 devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:DSPSubregionBott devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:DSPSubregionLeft devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:DSPSubregionRigh devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:DSPSubregionTop devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:DecimationHorizo devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:DecimationVertic devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:EventAcquisitio0 devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:EventAcquisitio1 devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:EventAcquisition devAsynInt32::initCommon drvUserCreate
2013/11/19 21:06:30.435 asynPortDriver:drvUserCreate: addr=0, cannot
ARAVISCAM1:CAM:EventError devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:EventExposureEnd devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:EventFrameTrigge devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:EventLine1Fallin devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:EventLine1Rising devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:EventLine2Fallin devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:EventLine2Rising devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:EventLine3Fallin devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:EventLine3Rising devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:EventLine4Fallin devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:EventLine4Rising devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:EventOverflow devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:EventsEnable1 devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:ExposureAutoAdju devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:ExposureAutoMax devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:ExposureAutoMin devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:ExposureAutoOutl devAsynInt32::initCommon drvUserCreate
2013/11/19 21:06:30.436 asynPortDriver:drvUserCreate: addr=0, cannot
ARAVISCAM1:CAM:ExposureAutoRate devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:ExposureAutoTarg devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:ExposureValue devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:FirmwareVerBuild devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:FirmwareVerMajor devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:FirmwareVerMinor devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:FrameStartTrigge devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:GainAutoAdjustTo devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:GainAutoOutliers devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:GainAutoRate devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:GainAutoTarget devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:GainValue devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:ImageSize devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:IrisAutoTarget devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:IrisVideoLevel devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:IrisVideoLevelMa devAsynInt32::initCommon drvUserCreate
2013/11/19 21:06:30.437 asynPortDriver:drvUserCreate: addr=0, cannot
ARAVISCAM1:CAM:IrisVideoLevelMi devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:LUTAddress devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:LUTBitDepthIn devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:LUTBitDepthOut devAsynInt32::initCommon drvUserCreate
find parameter LUTLoad
ARAVISCAM1:CAM:LUTLoad devAsynInt32::initCommon drvUserCreate
find parameter LUTSave
ARAVISCAM1:CAM:LUTSave devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:LUTSizeBytes devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:LensDriveDuratio devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:LensVoltage devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:LensVoltageContr devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:NonImagePayloadS devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:OffsetValue devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:PvGainAutoMax devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:PvGainAutoMin devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:RecorderPreEvent devAsynInt32::initCommon drvUserCreate
2013/11/19 21:06:30.438 asynPortDriver:drvUserCreate: addr=0, cannot
ARAVISCAM1:CAM:SensorBits devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:StreamBytesPerSe devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:StreamHoldCapaci devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:StrobeDelay devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:StrobeDuration devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:SyncInGlitchFilt devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:SyncInLevels devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:SyncOutLevels devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:TimeStampValueHi devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:TimeStampValueLo devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:VsubValue devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:WhitebalValueBlu devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:WhitebalValueRed devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:BalanceWhiteAut0_RBV devAsynInt32::initCommon drvUserCreate
find parameter BandwidthControlMode
ARAVISCAM1:CAM:BandwidthControl_RBV devAsynInt32::initCommon drvUserCreate
2013/11/19 21:06:30.439 asynPortDriver:drvUserCreate: addr=0, cannot
find parameter ColorTransformationSelector
ARAVISCAM1:CAM:ColorTransforma0_RBV devAsynInt32::initCommon drvUserCreate
find parameter ColorTransformationMode
ARAVISCAM1:CAM:ColorTransforma1_RBV devAsynInt32::initCommon drvUserCreate
find parameter ColorTransformationValueSelector
ARAVISCAM1:CAM:ColorTransforma2_RBV devAsynInt32::initCommon drvUserCreate
find parameter DefectMaskColumnEnable
ARAVISCAM1:CAM:DefectMaskColumn_RBV devAsynInt32::initCommon drvUserCreate
find parameter DefectMaskPixelEnable
ARAVISCAM1:CAM:DefectMaskPixelE_RBV devAsynInt32::initCommon drvUserCreate
find parameter EdgeFilter
ARAVISCAM1:CAM:EdgeFilter_RBV devAsynInt32::initCommon drvUserCreate
find parameter ExposureAutoAlg
ARAVISCAM1:CAM:ExposureAutoAlg_RBV devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:ExposureAuto_RBV devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:GainAuto_RBV devAsynInt32::initCommon drvUserCreate
2013/11/19 21:06:30.440 asynPortDriver:drvUserCreate: addr=0, cannot
find parameter IrisMode
ARAVISCAM1:CAM:IrisMode_RBV devAsynInt32::initCommon drvUserCreate
find parameter LUTMode
ARAVISCAM1:CAM:LUTMode_RBV devAsynInt32::initCommon drvUserCreate
find parameter LensDriveCommand
ARAVISCAM1:CAM:LensDriveCommand_RBV devAsynInt32::initCommon drvUserCreate
find parameter PvDummyFrameStartTriggerMode
ARAVISCAM1:CAM:PvDummyFrameStar_RBV devAsynInt32::initCommon drvUserCreate
find parameter PvDummyTriggerMode
ARAVISCAM1:CAM:PvDummyTriggerMo_RBV devAsynInt32::initCommon drvUserCreate
find parameter PvDummyTriggerSelector
ARAVISCAM1:CAM:PvDummyTriggerSe_RBV devAsynInt32::initCommon drvUserCreate
find parameter SensorType
ARAVISCAM1:CAM:SensorType_RBV devAsynInt32::initCommon drvUserCreate
2013/11/19 21:06:30.441 asynPortDriver:drvUserCreate: addr=0, cannot
find parameter StreamHoldEnable
ARAVISCAM1:CAM:StreamHoldEnable_RBV devAsynInt32::initCommon drvUserCreate
find parameter StrobeDurationMode
ARAVISCAM1:CAM:StrobeDurationMo_RBV devAsynInt32::initCommon drvUserCreate
find parameter StrobeSource
ARAVISCAM1:CAM:StrobeSource_RBV devAsynInt32::initCommon drvUserCreate
find parameter SyncInSelector
ARAVISCAM1:CAM:SyncInSelector_RBV devAsynInt32::initCommon drvUserCreate
find parameter SyncOutPolarity
ARAVISCAM1:CAM:SyncOutPolarity_RBV devAsynInt32::initCommon drvUserCreate
find parameter SyncOutSelector
ARAVISCAM1:CAM:SyncOutSelector_RBV devAsynInt32::initCommon drvUserCreate
find parameter SyncOutSource
ARAVISCAM1:CAM:SyncOutSource_RBV devAsynInt32::initCommon drvUserCreate
find parameter TriggerOverlap
ARAVISCAM1:CAM:TriggerOverlap_RBV devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:BalanceWhiteAut0 devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:BandwidthControl devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:ColorTransforma0 devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:ColorTransforma1 devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:ColorTransforma2 devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:DefectMaskColumn devAsynInt32::initCommon drvUserCreate
2013/11/19 21:06:30.442 asynPortDriver:drvUserCreate: addr=0, cannot
ARAVISCAM1:CAM:DefectMaskPixelE devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:EdgeFilter devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:ExposureAuto devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:ExposureAutoAlg devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:GainAuto devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:IrisMode devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:LUTMode devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:LensDriveCommand devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:PvDummyFrameStar devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:PvDummyTriggerMo devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:PvDummyTriggerSe devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:SensorType devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:StreamHoldEnable devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:StrobeDurationMo devAsynInt32::initCommon drvUserCreate
2013/11/19 21:06:30.443 asynPortDriver:drvUserCreate: addr=0, cannot
ARAVISCAM1:CAM:StrobeSource devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:SyncInSelector devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:SyncOutPolarity devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:SyncOutSelector devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:SyncOutSource devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:TriggerOverlap devAsynInt32::initCommon drvUserCreate
find parameter DevicePartNumber
ARAVISCAM1:CAM:DevicePartNumber_RBV devAsynOctet drvUserCreate failed
find parameter ModelName
ARAVISCAM1:CAM:ModelName_RBV devAsynOctet drvUserCreate failed
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 38799,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
epics>
Am 14.11.13 20:59, schrieb Mark Rivers:
> Hi Florian,
> I think the problem is simpler than you think.  Now that you have the complete version of areaDetector, you should be able to build and run the ararvis driver and example IOC.  Don't worry about the Prosilica application and example Prosilica IOC that is part of areaDetector.
> The DLS aravis driver needs to find the areaDetector base and plugin libraries.  Once it finds those successfully then the aravis driver and example IOC in the DLS package should build successfully, and you should be able to control the Basler camera with that example IOC.
> The only thing you should need to change is the aravis/configure/RELEASE file to point to the new version of areaDetector that you have installed and built.
> Let me know if you have more questions or problems.
> Mark
Florian Sorgenfrei
Institute for Methods and Instrumentation for Synchrotron Radiation
Research G-ISRR
Albert-Einstein-Str. 15
D-12489 Berlin
GERMANY
Tel.: +49 30 8062 12924
Fax: +49 30 8062 14987
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
RE: areaDetector for a Basler GigE camera tom.cobb
areaDetector for a Basler GigE camera Sorgenfrei, Florian
RE: areaDetector for a Basler GigE camera Mark Rivers
Re: areaDetector for a Basler GigE camera Florian Sorgenfrei
Prev: Re: Subscription updates halting? Gibbs, Matt
Next: RE: areaDetector for a Basler GigE camera tom.cobb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: areaDetector for a Basler GigE camera Florian Sorgenfrei
