1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: areaDetector for a Basler GigE camera
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Fri, 22 Nov 2013 09:52:16 +0000
The constantly changing pixel formats look suspicious. Is there a pv somewhere that will switch the camera into big endian mode? Maybe you could try setting the GETFEATURES pv to Off and see if that improves things? I don't have a Basler camera here to test unfortunately so I can't try any of these things...
Tom Cobb
> -----Original Message-----
> From: Florian Sorgenfrei [mailto:florian.sorgenfrei@helmholtz-
> berlin.de]
> Sent: 21 November 2013 13:46
> To: Cobb, Tom (DLSLtd,RAL,TEC); [email protected]; tech-
> [email protected]
> Subject: Re: areaDetector for a Basler GigE camera
> Hi Tom and Mark,
> here are a few error messages for Tom showing the pixel format error. I
> hope it helps somehow. It looks to me that the number is always
> different. I can send you the full output if necessary.
> 2013/11/20 19:52:02.506 aravisCamera:callback: unknown pixel format
> 402657792
> 2013/11/20 19:52:02.518 aravisCamera:lookupColorMode: Could not find a
> match for pixel format: 301995776
> 2013/11/20 19:52:02.518 aravisCamera:callback: unknown pixel format
> 301995776
> 2013/11/20 19:52:02.531 aravisCamera:lookupColorMode: Could not find a
> match for pixel format: 251663104
> 2013/11/20 19:52:02.531 aravisCamera:callback: unknown pixel format
> 251663104
> 2013/11/20 19:52:02.544 aravisCamera:lookupColorMode: Could not find a
> match for pixel format: 352327424
> 2013/11/20 19:52:02.544 aravisCamera:callback: unknown pixel format
> 352327424
> 2013/11/20 19:52:02.556 aravisCamera:lookupColorMode: Could not find a
> match for pixel format: 369102848
> Concerning the ImageJ problem was again trying today the things Mark
> suggested. I created the JCALibrary.properties file both on the Windows
> 7 and the OS X machine. It didn't change anything. The Epics Viewer can
> connect to the PV (green background) but when starting the plugin I get
> pendIO timed out errors. Afterwards I was trying the second approach
> using normal epics environment variables since the EPICS_AD viewer (if
> I'm right) is setting "jca.use_env=true". Again, the viewer can connect
> to the PV but starting the plugin gives the pendIO errors.
> Hence at the moment I can only view the images with imagej running on
> the server hosting the ioc. Unfortunately I don't have a linux box here
> to test the remote viewing there.
> Cheers,
> Flo
> Am 21.11.13 10:24, schrieb [email protected]:
> > Could you send me the errors you got with unknown pixel value? Some
> cameras don't like having their bit depth changed while acquiring, you
> might have to stop acquiring, wait for a few seconds, then change the
> bit depth... The aravisGigE driver maps the DataType (like Uint8) and
> ColorMode (like Mono) pvs to the PixelFormat (like Mono8) register. If
> you choose uint16 then it will try the highest bit depth the camera
> supports, but some cameras falsely report they do mono12 and then fail
> to produce the correct image type. You could try changing the DataType
> to uint16, then changing PixelFormat to Mono10 and seeing if that
> works...
> > Thanks,
> > Tom Cobb
> Florian Sorgenfrei
> Institute for Methods and Instrumentation for Synchrotron Radiation
> Research G-ISRR
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Albert-Einstein-Str. 15
> D-12489 Berlin
> GERMANY
> Tel.: +49 30 8062 12924
> Fax: +49 30 8062 14987
> ________________________________
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
> Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch,
> stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
> Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas
> Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
areaDetector for a Basler GigE camera Sorgenfrei, Florian
RE: areaDetector for a Basler GigE camera Mark Rivers
Re: areaDetector for a Basler GigE camera Florian Sorgenfrei
RE: areaDetector for a Basler GigE camera tom.cobb
Prev: RE: areaDetector for PGR Flea3 GigE camera tom.cobb
Next: Re: Convertion for asynFloat64 Benoit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: areaDetector for a Basler GigE camera Mark Rivers
Next: LIB_INSTALLS, static builds and .so files. Shankar, Murali
