1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Why should I care about breakpoint table monotonicity?
To: <[email protected]>
Date: Fri, 22 Nov 2013 12:01:19 -0600
On 11/22/2013 11:47 AM, Emmanuel Mayssat wrote:
What surprises me even more is that ***at compilation time*** dbExpand
(!?!?) check for the monotonicity.
In 3.14.x the same code that loads DBD files into the IOC is used in the dbExpand program, so it does the same checking. You can give dbExpand a -b flag to disable the monotonicity check though. Put
    DBEXPAND += -b
into your Makefile to add that flag to all calls to dbExpand (there is a USR_DBDFLAGS variable, but it also gets use for other programs which won't understand the -b flag so you probably don't want to use that).
HTH,
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
RE: Why should I care about breakpoint table monotonicity? Emmanuel Mayssat
RE: Why should I care about breakpoint table monotonicity? Hartman, Steven M.
Prev: RE: Why should I care about breakpoint table monotonicity? Emmanuel Mayssat
Next: Re: EpicsSharp issues Alain Bertrand
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Why should I care about breakpoint table monotonicity? Emmanuel Mayssat
