1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Why should I care about breakpoint table monotonicity?
To: "Johnson, Andrew N." <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 22 Nov 2013 10:56:57 -0800
> In 3.14.x the same code that loads DBD files into the IOC is used in the
> dbExpand program, so it does the same checking. You can give dbExpand a
> -b flag to disable the monotonicity check though. Put
> DBEXPAND += -b
> into your Makefile to add that flag to all calls to dbExpand (there is a
Not in 3.14.11...
epics2@cls1dev11 $ make
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[1]: Entering directory `/home/cls1fs/epics/2/git/epics-iocs/cls1/drv/records/bpt/O.linux-x86'
perl /home/local/epics/base/3.14.11/bin/linux-x86/makeIncludeDbd.pl bptTypeJdegC.dbd bptTypeKdegC.dbd bptTypeKdegX.dbd ../O.Common/recordsBptInclude.dbd
Expanding dbd
/home/local/epics/base/3.14.11/bin/linux-x86/dbExpand -b  -I . -I .. -I ../../../dbd -I/home/local/epics/base/3.14.11/dbd -I/home/local/epics/extras/3_14_11-20100623_104822/asyn/4-12-20110127_113101/dbd -I/home/local/epics/extras/3_14_11-20100623_104822/autosave/4-5-20110127_112910/dbd -I/home/local/epics/extras/3_14_11-20100623_104822/calc/2-7-20110127_113028/dbd -I/home/local/epics/extras/3_14_11-20100623_104822/genSub/1-6a-20110127_112851/dbd -I/home/local/epics/extras/3_14_11-20100623_104822/seq/2-0-12-20110127_112811/dbd -I/home/local/epics/extras/3_14_11-20100623_104822/sscan/2-6-5-20110127_112958/dbd -I/home/local/epics/extras/3_14_11-20100623_104822/stream/2-4a-20110127_113215/dbd -o ../O.Common/recordsBpt.dbd ../O.Common/recordsBptInclude.dbd
dbExpand: Unknown option '-b'
Usage:
        dbExpand -Ipath -ooutfile -S macro=value file1.dbd file2.dbd ...
Specifying any path will replace the default of '.'
make[1]: *** [../O.Common/recordsBpt.dbd] Error 1
make[1]: Leaving directory `/home/cls1fs/epics/2/git/epics-iocs/cls1/drv/records/bpt/O.linux-x86'
make: *** [install.linux-x86] Error 2
I tried -d, then I check the source code of dbExpand.
I can't find the code for such an option.
Am I missing something?
E
Re: Why should I care about breakpoint table monotonicity? Andrew Johnson
RE: Why should I care about breakpoint table monotonicity? Hartman, Steven M.
RE: Why should I care about breakpoint table monotonicity? Emmanuel Mayssat
Prev: Re: EpicsSharp issues Alain Bertrand
Next: Re: Why should I care about breakpoint table monotonicity? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Why should I care about breakpoint table monotonicity? Andrew Johnson
