1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Breakpoint tables: Raw value must be integer?!?
To: "'Emmanuel Mayssat'" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 22 Nov 2013 17:08:02 -0800
Hi Emmanuel,
> Is RVAL supposed to be an integer?
Yes.
> How can fix my current example?
I'm sure other people have a better solution but I use a subroutine record.  The logic looks something like this (I snipped code that you don't care about so maybe it doesn't compile):
#include <cvtTable.h>         /* for cvtRawToEngBpt      */
long subBLMagField(struct subRecord *psub)
   * Inputs:
   *          A = Gap      (mm)
   *          D = Breakpoint Table Index (index in menuConvert.dbd)
   * Outputs:
   *          H = Value from the Breakpoint Table
   *          J = Previous Breakpoint Table Index
   *       DPVT = Pointer to Breakpoint Table
   *          L = Last Breakpoint
   *        VAL = Magnetic Field    (T)
  short lbrk;        /* Last breakpoint              */
  long  lbrkStatus;  /* Breakpoint conversion status */
    if (psub->d != psub->j)
      psub->j = psub->d;
      psub->dpvt = 0;
    lbrk    = psub->l;
    psub->h = psub->a;
    lbrkStatus = cvtRawToEngBpt(&psub->h, (short)psub->d, 0,
                                &psub->dpvt, &lbrk);
    /* If at a breakpoint table limit, OK to use the limit (status = 1) */
    if ((lbrkStatus != 0) && (lbrkStatus != 1)) return -1;
    psub->l   = lbrk;
    psub->val = psub->h;
  return 0;
Hope this is helpful,
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Emmanuel Mayssat
> Sent: Friday, November 22, 2013 4:49 PM
> To: [email protected]
> Subject: Breakpoint tables: Raw value must be integer?!?
> I would like to replace a few of my existing CALC records (polynomial transformation)
> with simple breakpoint tables.
> Let's assume that my raw values are voltages between 0 and 5V, I could therefore build a
> transformation table as follow:
> breaktable(bptPosSlope) {
>         raw=0.000000 slope=9.000000e+00 eng=-27.000000
>         raw=1.000000 slope=1.800000e+01 eng=-18.000000
>         raw=2.000000 slope=1.800000e+01 eng=0.000000
>         raw=3.000000 slope=1.400000e+01 eng=18.000000
>         raw=4.000000 slope=3.000000e+00 eng=32.000000
>         raw=5.000000 slope=3.000000e+00 eng=35.000000
> Although the table allows for double/float transformation, to my surprise, the RAW value
> stored in the AI record is an integer.
> Maybe is it because of my INP link...
> This record is supposed to be the raw value
> clsXdev:6175>dbpr RECORDS:BrkpntTable:Rdbck:RawAI
> ASG:                DESC: Raw readback  DISA: 0             DISP: 0
> DISV: 1             NAME: RECORDS:BrkpntTable:Rdbck:RawAI   RVAL: 0
> SEVR: NO_ALARM      STAT: NO_ALARM      SVAL: 0             TPRO: 0
> VAL: 1.111
> Which is transformed in another ai record (which has its INP field pointing to the above
> record).
> clsXdev:6175>dbpr RECORDS:BrkpntTable:RdbckAI 3
> ACKS: NO_ALARM      ACKT: YES           ADEL: 0             ALST: -18
> AOFF: 0             ASG:                ASLO: 1             BKPT: 00
> DESC: Readback      DISA: 0             DISP: 0             DISS: NO_ALARM
> DISV: 1             DTYP: Raw Soft Channel                  EGU: mm
> EGUF: 0             EGUL: 0             EOFF: 0             ESLO: 1
> EVNT: 0             FLNK:CONSTANT 0     HHSV: NO_ALARM      HIGH: 0
> HIHI: 0             HOPR: 0             HSV: NO_ALARM       HYST: 0
> INIT: 0             INP:DB_LINK RECORDS:BrkpntTable:Rdbck:RawAI.VAL NPP NMS
> LALM: -18           LBRK: 0             LCNT: 0             LINR: bptPosSlope
> LLSV: NO_ALARM      LOLO: 0             LOPR: 0             LOW: 0
> LSV: NO_ALARM       MDEL: 0             MLST: -18
> NAME: RECORDS:BrkpntTable:RdbckAI       NSEV: NO_ALARM      NSTA:
> NO_ALARM
> ORAW: 1             PACT: 0             PHAS: 0             PINI: NO
> PREC: 3             PRIO: LOW           PROC: 0             PUTF: 0
> ROFF: 0             RPRO: 0             RVAL: 1             SCAN: 1 second
> SDIS:CONSTANT       SEVR: NO_ALARM      SIML:CONSTANT       SIMM: NO
> SIMS: NO_ALARM      SIOL:CONSTANT       SMOO: 0             STAT: NO_ALARM
> SVAL: 0             TIME: 2013-11-22 16:44:26.374133281     TPRO: 0
> TSE: 0              TSEL:CONSTANT       UDF: 0              VAL: -18
> Now for some reason the RVAL of this last record is = to 1 (and not 1.1111)
> As a result, the VAL is not calculated correctly.
> Thanks,
> Emmanuel
RE: Breakpoint tables: Raw value must be integer?!? Emmanuel Mayssat
Prev: Breakpoint tables: Raw value must be integer?!? Emmanuel Mayssat
Next: Anyone using StreamDevice with local serial ports on Windows? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Breakpoint tables: Raw value must be integer?!? Emmanuel Mayssat
