On Tuesday, November 26, 2013 17:57:43 Andrew Johnson wrote:
> On 11/26/2013 05:20 PM, Evgeniy wrote:
> > I can easily set scan period to 0.01 second by adding:
> > choice(menuScan_01_second,".01 second")
> > in dbd file.
> Note that if the IOC's processing of all the records that have
> SCAN=.01 second takes longer than 0.01 second to execute, the scan
> rate will drop to 10Hz automatically. The code in
> base/src/db/dbScan.c enforces this (3.14.12.4 will not be as strict,
> but does still limit the processing rate if it takes longer than the
> scan period to process all the records on the scan list).
I am shocked/confused.
Does that mean SCAN field and menuScan semantics will change from
3.14.12.3 to 3.14.12.4? I thought it was agreed upon to only make bug
fixes when increasing the patch level version (i.e. the 4th part of the
version number). New features would have to be in 3.15 or 3.14.13.
Could you clarify the versioning policy, please?
Cheers
"Make it so they have to reboot after every typo." ― Scott Adams
signature.asc
Description: This is a digitally signed message part.
- Re: Increasing scan rate to 10 kHz Benjamin Franksen
- Increasing scan rate to 10 kHz Evgeniy
- Re: Increasing scan rate to 10 kHz Andrew Johnson
Fw: Alarm Handler Swati Soni2
RES: Error with Asyn and rpcgen Lucas Jose Monteiro Carvalho
<2013>
2025
2026
<2013>
2025
2026
