Hi Evgeniy,
On 12/18/2013 01:07 PM, Evgeniy wrote:
> Processing of an EPICS record takes ~2 milliseconds on my SL5.3/DELL
> 2.27 GHz. It is unbelievably slow!
How are you measuring that? There is a problem with your measurement
methodology, as Mark Rivers has shown. How long it actually takes to
process a record is *not* the same as how often you can trigger it to
process, since the latter depends on what method you are using to
trigger its processing. Trying to create a very fast periodic thread is
never going to be an efficient way to make a record process very quickly.
You are likely to get more help from us here on tech-talk if you can
step back and explain what you are trying to achieve, i.e. give us the
big picture problem, not your current specific detail problem, because I
think you may be heading in the wrong direction.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Increasing scan rate to 10 kHz Evgeniy
- Re: Increasing scan rate to 10 kHz Andrew Johnson
- Re: Increasing scan rate to 10 kHz Evgeniy
- Re: Increasing scan rate to 10 kHz Eric Norum
RE: Increasing scan rate to 10 kHz Mark Rivers
RE: Design strategies for CSS BOY screens John Dobbins
<2013>
2025
2026
Re: Increasing scan rate to 10 kHz Benjamin Franksen
<2013>
2025
2026
