1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Mclennan PM600 motor controller
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 12 Dec 2013 04:24:47 +0000
Hi Mark
Thank you very much for the assistance.  As you may have gathered, EPICS is not a full time task for me, so assistance is much appreciated.
Indeed I am using the Mclennan driver.  Your direction allowed me to progress greatly, but I am at another stumbling block.  I have managed to communicate and move the motor through an asynRecord device by simply connecting to port "test-se-1" and address "0".  The .OEOS field must be set to "\r\n" for the commands to actually be acted upon (otherwise it just reads back the input command).  However, when I try connecting through a motor record, I get the trace below on IOC start up:
# Test SE (test-se1)
drvAsynIPPortConfigure("test-se1-1", "172.16.0.108:5300")
# Add these lines for asynTrace debugging
asynSetTraceIOMask("test-se1-1",0,2)
asynSetTraceMask("test-se1-1",0,9)
# Test for Mclennan PM600 stepper motor controller
# PM304Setup(controller count, poll rate (Hz))
# PM304Config(card being configured, asyn port name,  number of axes)
PM304Setup(1,5)
PM304Config(1, "test-se1-1", 1)
## Load record instances
dbLoadRecords("../../db/sum.db","INST=pitest")
Can't set "test:buncher:motor.OUT" to "@asyn(test-se1-1, 0)"
Error at or before ")" in file "../../db/sum.db" line 34
iocInit()
Starting iocInit
## EPICS R3.14.12.3 $Date: Mon 2012-12-17 14:11:47 -0600$
## EPICS Base built Aug 13 2013
Illegal field value PV: test:buncher:motor motor_init_record_com(): card does not exist!
I'm aware the last line means there is a communication issue, but I have no idea about the "Can't set to @asyn" line.  I assume from asyn_motor.db that that is correct format for that field.  In any case, I have tried a few different ways, but no dice.
The full db record is:
# Test record for Mclennan PM600 Stepper Motor driver
record(motor, "test:buncher:motor") {
  field(DTYP, "Mclennan PM304")
  field(OUT, "@asyn(test-se1-1, 0)")
  field(RRES, "1.0")
  field(PREC, "0")
  field(TWV, "10")
  field(VELO, "50")
Regards
Peter
-----Original Message-----
Sent: Wednesday, 11 December 2013 4:04 PM
To: Peter Linardakis; [email protected]
Hi Peter,
I assume you are using the McLennan driver that is included in synApps/motor/motorApp/MclennanSrc/?
If so, then the problem is the DTYP field in the motor record in your database. You specified
        field(DTYP, "asynMotor")
DTYP "asynMotor" is only for Model 2 and 3 motor drivers, where the communication between the motor record device support and the driver uses the standard asyn interfaces.
The Mclennan driver is an old Model 1 driver.  This is the correct definition of DTYP for the McLennan motors.
You can find that required string ("Mclennan PM304") by looking in the DBD file your application is including:
        pitest_DBD += devMclennanMotor.dbd
That file, motorApp/MclennanSrc/devMclennanMotor.dbd, contains the following line:
        device(motor,VME_IO,devPM304,"Mclennan PM304")
That tells you what the device support string name is.
Cheers,
RE: Mclennan PM600 motor controller Mark Rivers
RE: Mclennan PM600 motor controller nick.rees
Mclennan PM600 motor controller Peter Linardakis
Prev: areaDetector patches Bruce Hill
Next: RE: Mclennan PM600 motor controller Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Mclennan PM600 motor controller Mark Rivers
