1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: pilatus detecotr modify FileName problem
To: Matt Newville <[email protected]>
Cc: "[email protected] >> [email protected]" <[email protected]>
Date: Thu, 12 Dec 2013 20:59:02 +0000
The recent fix I referred to in my previous post was done in asyn 4-21 (Feb. 2013).  This is from the release notes for asynPortDriver:
Changed the code so that the length of string parameters returned in readOctet and octetCallback is now strlen(string)+1, rather than strlen(string). The length thus now includes the terminating nil. This fixes problems with clients that request long strings or subscribe to monitors with a length of 0, but don't check for a nil terminator.
That fix was discussed in detail in this tech-talk thread:
http://www.aps.anl.gov/epics/tech-talk/2012/msg02251.php
Note that this only has to do with reading strings, not with setting strings.
There was a related thread that involved problems with caput operations on long strings in 3.14.12.2:
http://www.aps.anl.gov/epics/tech-talk/2012/msg01693.php
From: [email protected] [[email protected]] on behalf of Mark Rivers [[email protected]]
Sent: Thursday, December 12, 2013 11:40 AM
To: Matt Newville
Cc: [email protected] >> [email protected]
Subject: Re: pilatus detecotr modify FileName problem
Hi Matt,
I don't recall that problem. If it existed it would almost certainly have been in asynPortDriver (part of asyn) and not in areaDetector itself. I was using IDL to set waveform strings almost from the start of areaDetector and it worked.
The one problem I do recall was quite recent and had to do with clients getting callbacks with such arrays which were not null terminated because they specified a length. I recently changed asyn so that it includes the null terminator in the callback and in the byte count. As I recall camonitor was such a client but it was also fixed by Ralph Lange.
Sent from my iPhone
> On Dec 12, 2013, at 9:12 AM, "Matt Newville" <[email protected]> wrote:
> Hi Mark,
> Do you recall a version of areaDetector where this (sending a short
> string, but NULL terminated) didn't work?   I don't remember this
> being a problem, but if the version of base is up to date, it's the
> only thing I could think of so far for why it wouldn't work...
> --Matt
Re: pilatus detecotr modify FileName problem Matt Newville
pilatus detecotr modify FileName problem 洪春霞
RE: pilatus detecotr modify FileName problem nick.rees
Re: pilatus detecotr modify FileName problem Bruce Hill
RE: pilatus detecotr modify FileName problem Mark Rivers
Re: pilatus detecotr modify FileName problem Mark Rivers
Prev: Re: pilatus detecotr modify FileName problem Mark Rivers
Next: RE: areaDetector patches Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: pilatus detecotr modify FileName problem Matt Newville
