Hi Mark
I had this nagging suspicion that I should indeed be basing my record on motor.db, but was confused from the motorR6-8 README file saying that serial devices needed asyn4-2. Live and learn I guess.
However, I still am unable to get it to work. The full record database is:
record(motor, "test:motor") {
field(DTYP, "Mclennan PM304")
field(OUT, "#C0 S0 @")
field(RRES, "1.0")
field(PREC, "0")
field(TWV, "10")
field(VELO, "50")
And the relevant part of the st.cmd file is
# Test SE (test-se1)
drvAsynIPPortConfigure("test-se1-1", "172.16.0.108:5300")
# Test for Mclennan PM600 stepper motor controller
# PM304Setup(controller count, poll rate (Hz))
# PM304Config(card being configured, asyn port name, number of axes)
PM304Setup(1,5)
PM304Config(0, "test-se1-1", 1)
I changed the PM304Config(0, "test-se1-1", 1) line from PM304Config(1, "test-se1-1", 1), since I assumed from the "#C0 S0" syntax that if I only have one card, then it must be card 0. In this case, the IOC seg faults immediately after boot.
If I leave it as PM304Config(1, "test-se1-1", 1), then the IOC runs, but you get the
Illegal field value PV: test:motor motor_init_record_com(): card does not exist!
line at start up.
Naturally, I'm lost.
Cheers
Peter
-----Original Message-----
Sent: Friday, 13 December 2013 2:11 AM
To: [email protected]; Peter Linardakis; [email protected]
Subject: RE: Mclennan PM600 motor controller
> The DTYP should be asynMotor - all new style motors drivers have the
> same DTYP since they share the same device support.
No, I don't think so. Peter is using the McLennan support in the synApps motor module, which is an old-style Model 1 driver, not a newer Model 2 or Model 3 driver using the asyn interfaces.
He originally had both the incorrect DTYP and OUT link specification for the motor. My first post had him correct the DTYP, but he still had a problem with OUT. I hope it will work once he corrects OUT to have the proper VMEIO syntax, e.g.
field(OUT,"#C0 S0 @")
From: [email protected] [[email protected]] on behalf of [email protected] [[email protected]]
Sent: Thursday, December 12, 2013 3:15 AM
To: [email protected]; [email protected]
Hi Peter,
The DTYP should be asynMotor - all new style motors drivers have the same DTYP since they share the same device support.
Cheers,
Nick Rees
Principal Software Engineer Phone: +44 (0)1235-778430
Diamond Light Source Fax: +44 (0)1235-446713
From: [email protected] [mailto:[email protected]] On Behalf Of Peter Linardakis
Sent: 12 December 2013 04:25
To: Mark Rivers; [email protected]
Hi Mark
Thank you very much for the assistance. As you may have gathered, EPICS is not a full time task for me, so assistance is much appreciated.
Indeed I am using the Mclennan driver. Your direction allowed me to progress greatly, but I am at another stumbling block. I have managed to communicate and move the motor through an asynRecord device by simply connecting to port "test-se-1" and address "0". The .OEOS field must be set to "\r\n" for the commands to actually be acted upon (otherwise it just reads back the input command). However, when I try connecting through a motor record, I get the trace below on IOC start up:
drvAsynIPPortConfigure("test-se1-1", "172.16.0.108:5300") # Add these lines for asynTrace debugging
asynSetTraceIOMask("test-se1-1",0,2)
asynSetTraceMask("test-se1-1",0,9)
# Test for Mclennan PM600 stepper motor controller # PM304Setup(controller count, poll rate (Hz)) # PM304Config(card being configured, asyn port name, number of axes)
PM304Setup(1,5)
## Load record instances
dbLoadRecords("../../db/sum.db","INST=pitest")
Can't set "test:buncher:motor.OUT" to "@asyn(test-se1-1, 0)"
Error at or before ")" in file "../../db/sum.db" line 34
iocInit()
Starting iocInit
## EPICS R3.14.12.3 $Date: Mon 2012-12-17 14:11:47 -0600$ ## EPICS Base built Aug 13 2013 ############################################################################
Illegal field value PV: test:buncher:motor motor_init_record_com(): card does not exist!
I'm aware the last line means there is a communication issue, but I have no idea about the "Can't set to @asyn" line. I assume from asyn_motor.db that that is correct format for that field. In any case, I have tried a few different ways, but no dice.
The full db record is:
# Test record for Mclennan PM600 Stepper Motor driver record(motor, "test:buncher:motor") {
field(OUT, "@asyn(test-se1-1, 0)")
field(RRES, "1.0")
field(PREC, "0")
field(TWV, "10")
field(VELO, "50")
Regards
Peter
Sent: Wednesday, 11 December 2013 4:04 PM
To: Peter Linardakis; [email protected]
Hi Peter,
I assume you are using the McLennan driver that is included in synApps/motor/motorApp/MclennanSrc/?
If so, then the problem is the DTYP field in the motor record in your database. You specified
field(DTYP, "asynMotor")
DTYP "asynMotor" is only for Model 2 and 3 motor drivers, where the communication between the motor record device support and the driver uses the standard asyn interfaces.
The Mclennan driver is an old Model 1 driver. This is the correct definition of DTYP for the McLennan motors.
You can find that required string ("Mclennan PM304") by looking in the DBD file your application is including:
pitest_DBD += devMclennanMotor.dbd
That file, motorApp/MclennanSrc/devMclennanMotor.dbd, contains the following line:
device(motor,VME_IO,devPM304,"Mclennan PM304")
That tells you what the device support string name is.
Cheers,
- RE: Mclennan PM600 motor controller Mark Rivers
- Mclennan PM600 motor controller Peter Linardakis
- RE: Mclennan PM600 motor controller Peter Linardakis
- RE: Mclennan PM600 motor controller nick.rees
Re: pilatus detecotr modify FileName problem Matt Newville
<2013>
2025
2026
<2013>
2025
2026
