1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: garbage in zero length arrays
To: <[email protected]>
Date: Thu, 16 Jan 2014 12:45:46 +0100
Hi all,
When monitoring a non initialized char array with ca_add_event_array, one gets most of the time in the first element of the array.
This only when the request uses ca_element_count(chid) which is non zero. When using the dynamic behavior by specifiying 0 elements, the received args.count correspond to the actual size of the array, including zero when not initialized.
My question is: when specifying 0, how does that behave in older epics versions and channel access gateways. Does it use then the maximum amount of elements ?
Anton
__________________________________________
Paul Scherrer Institut
Dr. Anton Christian Mezger
WBGB/103
CH-5232 Villigen PSI
Telefon: +41 56 310 34 06
E-Mail: [email protected]
RE: garbage in zero length arrays Hill, Jeff
Re: garbage in zero length arrays Ralph Lange
Prev: Re: Sequencer Installation error Jitendra Kodilkar
Next: Re: Sequencer Installation error Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re:Re: Failed to install ISR 류수
Next: RE: garbage in zero length arrays Hill, Jeff
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
