1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: garbage in zero length arrays
To: Mezger Anton Christian <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 16 Jan 2014 16:07:28 +0000
Ø  My question is: when specifying 0, how does that behave in older epics versions and channel
Ø  access gateways. Does it use then the maximum amount of elements ?
When a channel connects the maximum number of elements is supplied by the server as a channel attribute. In newer versions of EPICS the current number of elements is returned with each subscription update. In older versions the maximum number of elements was always returned; when the current number of elements was less than the maximum number then any additional elements at the end were zero padded.
Jeff
From: [email protected] [mailto:[email protected]] On Behalf Of Mezger Anton Christian
Sent: Thursday, January 16, 2014 4:46 AM
To: [email protected]
Subject: garbage in zero length arrays
Hi all,
When monitoring a non initialized char array with ca_add_event_array, one gets most of the time in the first element of the array.
This only when the request uses ca_element_count(chid) which is non zero. When using the dynamic behavior by specifiying 0 elements, the received args.count correspond to the actual size of the array, including zero when not initialized.
My question is: when specifying 0, how does that behave in older epics versions and channel access gateways. Does it use then the maximum amount of elements ?
Anton
__________________________________________
Paul Scherrer Institut
Dr. Anton Christian Mezger
WBGB/103
CH-5232 Villigen PSI
Telefon: +41 56 310 34 06
E-Mail: [email protected]
RE: garbage in zero length arrays Mezger Anton Christian
Prev: RE: PV for both input AND output Mark Rivers
Next: RE: garbage in zero length arrays Mezger Anton Christian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: garbage in zero length arrays Mezger Anton Christian
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
