FWIW, this example using Stream Device and write/read communication with
a field device receives a command string from a "user" via Channel
Access, sends that to the field device, waits for the response, and then
places that response back into the same stringout record for the "user"
to read:
Stream protocol fragment from write_read.proto:
debug {
out "%s";
in "%39c";
EPICS database fragment:
record(stringout, "$(P)cmd") {
field(DESC, "command interface")
field(DTYP, "stream")
field(OUT, "@write_read.proto debug $(PORT)")
Pete
On 1/16/2014 10:54 AM, Andrew Johnson wrote:
Hi Matteo,
On 01/16/2014 09:33 AM, Matteo Pardi wrote:
Can I create a process variable which will have a callback to read data,
and a callback to write data?
The API between a record type and its device support is set by the
designer of the record type. If you want a record type that does both
input and output you can create one yourself with both a read and a
write function in the DSET. The IOC only requires that the DSET
structure starts like this:
struct my_dset { /* device support entry table */
long number; /* number of support routines */
DEVSUPFUN report; /* print report */
DEVSUPFUN init; /* init support layer */
DEVSUPFUN init_record; /* init device for particular record */
DEVSUPFUN get_ioint_info; /* get io interrupt information */
/* Other functions go here and are record-type specific */
You can add as many additional functions to the DSET as you need to
implement the desired interface between the record and the device.
When you write your own record type though you do have to write all the
associated device support layers as well, the support layers provided by
Asyn or StreamDevice say will not work directly with your new type,
although you may be able to use them as examples and re-use their driver
layer.
Note that a record type must have a link field called either INP or OUT
to properly connect to device support.
Hope this helps,
- Andrew
Pete R. Jemian, Ph.D. <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source, Argonne National Laboratory
Argonne, IL 60439 630 - 252 - 3189
Education is the one thing for which people
are willing to pay yet not receive.
- PV for both input AND output Matteo Pardi
- Re: PV for both input AND output Andrew Johnson
RE: PV for both input AND output Mark Rivers
<2014>
2025
2026
Re: PV for both input AND output Ralph Lange
<2014>
2025
2026
