Hi Matteo,
in addition to the solutions posted, that use two records to split the
writing and reading operations, it is also feasible to completely manage
things in the device support layer, while using one (output) record for
both operations.
To achieve that, the device support keeps a flag in its
per-record-instance structure to remember the type of the next
operation. For a set point using an output record, the normal state of
the flag would be "write".
To work reliably, a write operation to the device must return the
current value of that set point - either as an integral part of the
protocol, or by the device support doing a read request immediately
after writing the value.
When the device support receives a value from the device (either by
polling or by an unsolicited message from the device), it caches the
value, sets the flag of the affected record to "read", sets PACT and
requests the record being processed through a callbackRequest function -
initiating the second pass of an asynchronous processing.
The write() routine of the device support checks the per-record flag. If
it is set to "write", it initiates a write request to the device, sets
PACT, and returns. If it is set to "read", it reads the cached value
from the device support, sends out monitors, resets PACT and the flag,
and returns.
Race conditions appear if the IOC and another local master both write
the value at (roughly) the same time. But these can not be avoided - no
matter how hard you try to manage, if two masters write at the same
time, only one will win. The important aspect: your device must forward
all value changes in set points to the IOC, so that the record always
shows the current value - no matter which master wins the race.
This method is being used by a couple of device supports dealing with
"intelligent" devices with optional local control, namely PLCs through
OPC or other protocols.
Cheers,
~Ralph
- PV for both input AND output Matteo Pardi
RE: A call to 'assert(capacity != 0)' by thread Emmanuel Mayssat
CAJ "AlreadyBoundException" Mezger Anton Christian
<2014>
2025
2026
Re: PV for both input AND output Pete Jemian
<2014>
2025
2026
ANJ, 17 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
