I'm using SNL to perform a potentially long put_callback, using pvPut with the ASYNC option in one state, followed by the use of pvPutComplete in the following state. Then on completion, I read another PV immediately, which has an SNL monitor on it, something like:
unsigned short start_pv; assign start_pv to "{RC}:Start"; monitor start_pv;
unsigned short login_pv; assign login_pv to "{DAS}:Login";
unsigned short status_pv; assign status_pv to "{DAS}:Stat"; monitor status_pv;
state idle {
/* When we detect a user start. */
when (start_pv == 1) {
login_pv = 1;
pvPut(login_pv, ASYNC);
} state login
state login {
when (pvPutComplete(login_pv)) {
if (status_pv != 1) {
/*handle error here*/
} else {
/*it worked */
} state thenextstate
I have a race condition between the completion of the put_callback and the status_pv variable updating due to a monitor. I sometimes read the value the status PV had before the callback completes. I've tested the underlying system quite a bit, so I suspected a problem with my SNL. I added in a pvGet(status_pv) just before I test that variable, and it seems to have solved it (which maybe just due to the extra time taken to execute the pvGet).
Am I handling this situation incorrectly, or do we know of a problem with monitors in SNL (SEQ Version 2.0.14)? Is the use of pvGet on a monitored variable a bad idea? From reading tech-talk, it might be frowned upon...
Or, is there a better way of doing this, using event flags?
Cheers,
Matt
- RE: SNL monitor and pvPutComplete Emmanuel Mayssat
DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] LYNCH, Damien
Re: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] Jon Nielsen
<2014>
2025
2026
RE: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] ronaldo.mercado
<2014>
2025
2026
