1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Cross compilation for linux-arm on target SBC (TS-7300)
To: Azra Jabeen <[email protected]>, EPICS mailing list <[email protected]>
Date: Thu, 30 Jan 2014 09:48:45 -0800
if you look at the first line of your st.cmd, you will see it is referencing the myexample interpreter with path that appears in the error message
So either (1) the path is incorrect or (2) you haven't copied the binary file myexample from your host to your target hardware
Building EPICS/asyn/etc on TS7xxx has been done before.
So you are almost there. Good luck!
Emmanuel
Date: Thu, 30 Jan 2014 10:10:01 +0500
Subject: Cross compilation for linux-arm on target SBC (TS-7300)
To: [email protected]
I build IOC for target SBC with linux-arm and copy only Application folder to SBC . When I run .st.cmd I got error
bash: ./st.cmd: ../../bin/linux-arm/myexample: bad interpreter: No such file or directory
Please some one help me?
Cross compilation for linux-arm on target SBC (TS-7300) Azra Jabeen
Prev: .NET client and server availble as NuGet packages Bertrand Alain Gregor
Next: RE: Command to print out dynamically assigned TCP port Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Cross compilation for linux-arm on target SBC (TS-7300) Azra Jabeen
Next: .NET client and server availble as NuGet packages Bertrand Alain Gregor
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
