1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Command to print out dynamically assigned TCP port
To: "Shankar, Murali" <[email protected]>, EPICS mailing list <[email protected]>
Date: Thu, 30 Jan 2014 10:49:40 -0800
Why do you want a display in the IOC shell?
netstat -u -p
can do the job.
If you start IOCs with the same binary, you may need to know the process PID.
To prevent this, use hardlinks
$ ln clsXdev-3_14_1 ocbin-1
$ ln clsXdev-3_14_1 ocbin-2
[starts 3 IOCs with same binary]
$ netstat  -u -p
Active Internet connections (w/o servers)
Proto Recv-Q Send-Q Local Address               Foreign Address             State       PID/Program name
udp        0      0 cls1jin:35605               cls1jin:44647               ESTABLISHED 3543/caRepeater
udp        0      0 172.17.4.56:49833           cls1lan:ca-2                ESTABLISHED 11629/iocbin-1
udp        0      0 172.17.4.56:59837           cls1lan:ca-2                ESTABLISHED 3511/clsXdev-3_14_1
udp        0      0 172.17.4.56:49742           cls1lan:ca-2                ESTABLISHED 8751/iocbin-2
Emmanuel
To: [email protected]
Date: Wed, 29 Jan 2014 13:32:11 -0800
Subject: Command to print out dynamically assigned TCP port
Hello,
   If I start up multiple IOC’s on the same linux server, the IOC’s that start up later use a dynamically assigned TCP port.
>>> cas warning: Configured TCP port was unavailable.
>>> cas warning: Using dynamically assigned TCP port 33470,
  Just curious, is there an EPICS IOC shell command that prints out/displays this port?
Murali
Re: Command to print out dynamically assigned TCP port Andrew Johnson
Command to print out dynamically assigned TCP port Shankar, Murali
Prev: RE: Cross compilation for linux-arm on target SBC (TS-7300) Emmanuel Mayssat
Next: Re: Command to print out dynamically assigned TCP port Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Command to print out dynamically assigned TCP port Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
