1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: TPRO Field Definition
To: "[email protected] Talk" <[email protected]>
Date: Fri, 31 Jan 2014 14:27:07 +0000
I’m looking through the Documentation on "Fields common to all record types", and I see that TPRO is defined as:
which seems to imply that the only valid contents are 0 or 1.
I see that TPRO is defined as a UCHAR, in the section earlier, so I am wondering…..
I need to print varied amounts of information on a record as it’s being processed, during a debugging session, so can I  plan on using values assigned in TPRO -other- than just 0 and 1  (2,3….) to vary the amount of information printed by the device driver.
Unless this is a problem,  can the definition of that field be adjusted to state that numbers greater than 0 print information on the record each time it is processed?
Later-
David Dudley
Re: TPRO Field Definition Michael Davidsaver
Prev: importing jar files from CSS Python script Hovanes Egiyan
Next: Re: TPRO Field Definition Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: importing jar files from CSS Python script Hovanes Egiyan
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
