1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: importing jar files from CSS Python script
To: Xihui Chen <[email protected]>
Cc: [email protected], "[email protected]" <[email protected]>
Date: Wed, 05 Feb 2014 15:07:55 -0500
Hi Xihui,
I followed that example, it works.
    Hovanes.
On 02/03/2014 02:34 AM, Xihui Chen wrote:
Hi Hovanes,
I think adding jar file path to your sys.path should work. Fro example, the scan client is using this way to import scan related jar files to BOY script:
Xihui
On Thu, Jan 30, 2014 at 1:38 PM, Hovanes Egiyan <[email protected]> wrote:
we are trying to have a Python/Jython script associated with a widget in CSS BOY to work
with a SQLite database using sqlite-jdbc. When we try to import "org.sqlite" , the "import"
statement fails even if we add  the actual jar-file full name to "sys.path" (which is somewhere in
my home directory). It looks as if the "import"-statement does not care what the "sys.path"
variable is. I could do this using regular Jython 2.5.2, but we are having problem doing this
with CSS. How can we use external jar-files in the Python scripts in CSS, are these things
in CSS Python scripts supposed to work as they do in Jython?
Our current goal is to be able to read data from MySQL and SQLite databases
from our CSS BOY scripts. Any help would be appreciated.
    Hovanes Egiyan.
importing jar files from CSS Python script Hovanes Egiyan
Re: importing jar files from CSS Python script Xihui Chen
Prev: Re: TPRO Field Definition Andrew Johnson
Next: CSS 3.2.14 Cannot get PyDev installed Amien Crombie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: importing jar files from CSS Python script Xihui Chen
Next: TPRO Field Definition Dudley, David
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
