1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: aSub and "user defined structures" ?
To: <[email protected]>
Date: Wed, 5 Feb 2014 10:42:34 -0600
Hi Christophe,
On 02/05/2014 07:49 AM, haquin wrote:
> UFA ... UFU, UFVA ... UFVU fields of the genSub record no longer exist
> in the aSub record,
> I understand that the use of "user defined structures" is not possible
> with aSub record or there is another way to do ?
If you want to use those fields you can still use the genSub record type
instead of the aSub (genSub was never included in Base anyway, you have
always had to build it as an external module). I removed the UF* fields
when I converted the genSub into the aSub because users need to
understand their limitations to use them safely.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
aSub and "user defined structures" ? haquin
Prev: aSub and "user defined structures" ? haquin
Next: RE: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] ronaldo.mercado
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: stdout/stderr buffering on Windows freddie.akeroyd
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
