1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: stdout/stderr buffering on Windows
To: <[email protected]>
Date: Wed, 5 Feb 2014 17:59:08 +0000
just posting a note on an issue we have come across in case it is helpful to anybody else. We are using Cygwin procServ on Windows to start IOCs (Windows 7 / EPICS BASE 3.14.12.2) and, although stdout was appearing when we typed commands in the telnet window, stderr was not. When the IOC exited, however, the stderr output appeared so it seems that stderr was being buffered. I added the line:
    setvbuf (stderr, NULL, _IONBF, BUFSIZ);
to the IOC main and stderr output then appeared as expected - I think stdout was appearing OK as epicsReadline() does a flush(stdout) after writing the prompt. A "google" on the subject returned some references to this sort of behaviour when the Windows runtime does not recognize the connection as a "terminal" - running the IOC directly in a console windows certainly work OK
Freddie
Scanned by iCritical.
Re: stdout/stderr buffering on Windows Andrew Johnson
Prev: RE: DLS EtherCAT scanner and unmatched datagrams [SEC=UNCLASSIFIED] ronaldo.mercado
Next: Re: stdout/stderr buffering on Windows Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: aSub and "user defined structures" ? Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
