On 2/6/14, 10:18 AM, [email protected] wrote:
> Hi Andrew,
>> I do not see that buffering behaviour when running an IOC in a Cygwin
>> OpenSSH session either.
> Thanks for doing that - it prompted me to do a bit more
> investigating. On my Cygwin installation there are several ways to
> create a terminal - mintty, bash, and xterm. If I run a native windows
> compiled softIoc.exe in the bash terminal window, all works fine. If
> I run it in a mintty terminal window, I don't see any standard error
> output until I exit the IOC - then it all appears on screen. A Cygwin
> xterm window behaves the same - no stderr until the IOC is exited. If
> I type "tty" in the respective Cygwin windows, I see that mintty and
> xterm are both pseudo terminals whereas bash is a console session - I
> believe procServ uses forkpty(). So I think it boils down to Windows
> treating a Cygwin pty as non-interactive and thus buffering both
> stdout and stderr - I don't know whether it is possible to convince
> Windows to treat a Cygwin pty as a real terminal session? As you
> mentioned, the C99 standard mandates stderr to always be unbuffered so
> Windows is certainly not conforming here!
Hi, Freddie.
What does the following Bourne shell command print for your three
scenarios?
$ test -t 0 && echo 'connected to terminal'
Lewis
- stdout/stderr buffering on Windows freddie.akeroyd
- Re: stdout/stderr buffering on Windows Andrew Johnson
- RE: stdout/stderr buffering on Windows freddie.akeroyd
RE: CSS 3.2.14 Cannot get PyDev installed Emmanuel Mayssat
Re: stdout/stderr buffering on Windows J. Lewis Muir
<2014>
2025
2026
<2014>
2025
2026
