1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: stdout/stderr buffering on Windows
To: Andrew Johnson <[email protected]>, [email protected]
Date: Thu, 06 Feb 2014 18:33:00 -0600
On 2/6/14, 3:37 PM, Andrew Johnson wrote:
>> Was that a Windows IOC or a Cygwin IOC?
> That IOC was built for the cygwin-x86 target architecture.
> Hmm, trying it again on an IOC built using Microsoft VS10 shows the
> behaviour that Freddie described: stdout is line-buffered (I have to
> press return at the iocsh prompt for a background task's messages to
> appear), and stderr messages don't appear until I exit the IOC.
> Interesting, thanks for asking that.
> Your "test -t" check says that FDs 0, 1 and 2 are all connected to a
> terminal BTW.
Hi, Andrew.
OK, then maybe the problem is with Cygwin's pseudo terminal emulation
which uses pipes?  From what I can gather, this is a known weakness.
And a solution may not be straightforward since the Cygwin people would
have fixed it by now if it was?  I don't know enough about it to say.
The following mintty issue has some helpful comments (andy.koppe is the
mintty author):
  https://code.google.com/p/mintty/issues/detail?id=56
Comment #13 suggests the best way to avoid the problem is to use Cygwin
programs under Cygwin terminals and Windows programs under Windows
consoles.
Comment #49 mentions a program called winpty that adapts a Windows
console to the Cygwin terminal by creating a hidden Windows console and
polling it for changes.  It's at:
  https://github.com/rprichard/winpty
Lewis
stdout/stderr buffering on Windows freddie.akeroyd
Re: stdout/stderr buffering on Windows Andrew Johnson
Re: stdout/stderr buffering on Windows J. Lewis Muir
Prev: Re: stdout/stderr buffering on Windows Andrew Johnson
Next: RE: CSS 3.2.14 Cannot get PyDev installed Amien Crombie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: CSS 3.2.14 Cannot get PyDev installed Amien Crombie
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
