1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn driver problem running Linux 3.8.13 with arm processor
To: [email protected]
Date: Fri, 07 Feb 2014 10:23:03 -0800
I would also suggest that you provide as much detail as you can (e.g., complete code)
rather than snippets.
On 02/07/2014 09:13 AM, Andrew Johnson wrote:
Hi Jim,
On 02/07/2014 10:38 AM, Jim Chen wrote:
while(1) {
         /* Wait for event from interrupt routine */
printf("====before\n");
        epicsMessageQueueReceive(intMsgQId, data, sizeof(data));
printf("====queue responsed\n");
What does the code at the other end of the message queue look like? Does
it get called from interrupt context, or from task-level?
The problem might be that you can't use C++ code inside an ARM ISR (I
don't know whether that's true or not, but it's conceivable), and since
the libCom/osi/os/default/osdMessageQueue.cpp implementation is written
in C++ the problem is with the choice of using the epicsMessageQueue
inthe first place. As I said I don't know whether that is a restriction
but it's something you should check.
- Andrew
RE: asyn driver problem running Linux 3.8.13 with arm processor Jim Chen
RE: asyn driver problem running Linux 3.8.13 with arm processor Mark Rivers
Re: asyn driver problem running Linux 3.8.13 with arm processor Andrew Johnson
Prev: Re: motorRecord on linux-arm Till Straumann
Next: Re: Binding an IOC to a single network interface Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asyn driver problem running Linux 3.8.13 with arm processor Andrew Johnson
Next: RE: asyn driver problem running Linux 3.8.13 with arm processor Jim Chen
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
