1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: motorRecord on linux-arm
To: Ron Sluiter <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 07 Feb 2014 09:57:19 -0800
Shudder again.
I recommend a look at the c99 standard (6.7.2.1; paragraph 10)
An implementation may allocate any addressable storage unit large enough to hold a bit- field. If enough space remains, a bit-field that immediately follows another bit-field in a structure shall be packed into adjacent bits of the same unit. If insufficient space remains, whether a bit-field that does not fit is put into the next unit or overlaps adjacent units is implementation-defined. The order of allocation of bit-fields within a unit (high-order to low-order or low-order to high-order) is implementation-defined. The alignment of the
addressable storage unit is unspecified.
Hence any assumption about what storage unit the compiler uses, how adjacent bits are packed across a storage-unit boundary and in what order bits are allocated (LSB->MSB or MSB->LSB) is *not*portable*. This may change from compiler to compiler
- even from one version to another.
IMHO it is not a good idea to use bitfields the way the motor code does (i.e., making assumptions about their layout). You can find a lot of discussions on the
subject in the forums.
- Till
PS:
Just for illustration of the point:
struct A {
   unsigned long  a1: 24;
   unsigned long  a2: 24;
   unsigned short a3: 16;
is stored (by gcc-4.7.3) into 3 32-bit words (i386) or one 64-bit word (x86_64),
respectively.
Another one: the same gcc packs bitfields together differently (admittedly in
a way we'd expect it to do it) depending on whether we use chars or shorts:
union BF4 {
    struct {
        unsigned char a: 4;
        unsigned char b: 8;
    } charfield;
    struct {
        unsigned short a: 4;
        unsigned short b: 8;
    } shortfield;
int
main()
union BF4 bf;
    printf("Sizeof union:      %i\n",  sizeof(bf));
    printf("Sizeof charfield:  %i\n", sizeof(bf.charfield));
printf("Sizeof shortfield: %i\n", sizeof(bf.shortfield)); memset(&bf, 0, sizeof(bf));
    /* set 'a' via charfield */
    bf.charfield.a = 0xf;
    /* read-back as shortfield */
    printf("0x%1x  -- expected 0xf\n", bf.shortfield.a);
    /* set 'b' via charfield */
    bf.charfield.b = 0xff;
    printf("0x%1x -- expected 0xff\n", bf.shortfield.b);
}.4)
However: the point is that there is no *guarantee* for a particular layout.
Search the gcc documentation for '-Wpacked-bitfield-compat' for a case
where the layout changed between gcc versions (around 4.4).
On 02/07/2014 07:56 AM, Ron Sluiter wrote:
On 2/7/2014 9:21 AM, [email protected] wrote:
I suggest to remove the switch and replace the occurrence of  MSB_First with the EPICS provided endianness switch:
+#include <epicsEndian.h>
-#ifdef MSB_First
+#if (EPICS_BYTE_ORDER == EPICS_ENDIAN_BIG)
Thanks for the suggestion but MSB_First/LSB_First is set to indicate how
C/C++ bit fields are packed, not endianness.
What compiler and compiler version are you using?
Ron
motorRecord on linux-arm Jens . Eden
Re: motorRecord on linux-arm Ron Sluiter
Prev: Re: asyn driver problem running Linux 3.8.13 with arm processor Andrew Johnson
Next: Re: asyn driver problem running Linux 3.8.13 with arm processor Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: motorRecord on linux-arm Ron Sluiter
Next: Re: motorRecord on linux-arm Till Straumann
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
