1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: motorRecord on linux-arm
To: <[email protected]>
Date: Fri, 7 Feb 2014 09:56:11 -0600
On 2/7/2014 9:21 AM, [email protected] wrote:
I suggest to remove the switch and replace the occurrence of  MSB_First with the EPICS provided endianness switch:
+#include <epicsEndian.h>
-#ifdef MSB_First
+#if (EPICS_BYTE_ORDER == EPICS_ENDIAN_BIG)
Thanks for the suggestion but MSB_First/LSB_First is set to indicate how C/C++ bit fields are packed, not endianness.
What compiler and compiler version are you using?
Ron
Re: motorRecord on linux-arm Till Straumann
motorRecord on linux-arm Jens . Eden
Prev: RE: asyn driver problem running Linux 3.8.13 with arm processor Mark Rivers
Next: Re: motorRecord on linux-arm Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: motorRecord on linux-arm Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
