1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asyn driver problem running Linux 3.8.13 with arm processor
To: Jim Chen <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 7 Feb 2014 15:36:14 +0000
I don't know anything about the arm processor, so hopefully others can answer this.
Have you obtained a stack trace with gdb?
Sent: Friday, February 07, 2014 9:32 AM
To: Mark Rivers; [email protected]
Hi Mark,
Last time we discovered that those functions cannot be used in interrupt
service routine and I think that makes sense.
The queuetask is a message queue created by epicsMessageQueueCreate waiting
interrupt in a thread created by epicsThreadCreate. The strange thing is
that in other arch and Linux, it works fine. Is it anything to do with arm
processor or the 3.8.13 Linux distro or the gcc compiler?
Jim
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: 07 February 2014 15:10
> To: Jim Chen; [email protected]
> I don't know anything about the queuetask, but I have a guess about what
> could be causing the problem.  The getIntegerParam, etc. functions use C++
> try/catch blocks, because the underlying classes can throw exceptions.
> Perhaps exceptions are not allowed in queuetask?
> Mark
> From: [email protected] [[email protected]] on
> behalf of Jim Chen [[email protected]]
> Sent: Friday, February 07, 2014 8:47 AM
> To: [email protected]
> Subject: asyn driver problem running Linux 3.8.13 with arm processor
> Hello,
> Has anybody experienced segmentation fault when using asynPortDriver
> parameter interfaces such as
>         getIntegerParam
>         setIntegerParam
>         setDoubleParam
> in the queuetask in Linux 3.8.13 for arm processor?
> My environment is an EPICS application on BeagleBone Black:
>         Platform: BeagleBone Black
>         Processor: ARMv7 Processor rev 2 (v7l)
>         Linux distro: Angstrom Linux version 3.8.13 (koen@rrMBP) (gcc
version
> 4.7.3 20130205 (prerelease) (Linaro GCC 4.7-2013.02-01) ) #1 SMP Thu Sep
12
> 10:27:06 CEST 2013
>         EPICS R3.14.12.3
>         Asyn4-22/4-18
> Everything else works fine until an interrupt which wakes up the
queuetask.
> Inside the queuetask, any of those parameter interfaces causes the
> segmentation fault.
> I have tried the same code in other arch like Intel but running Scientific
Linux
> without problem.
> Any idea?
> Thanks,
> Jim
asyn driver problem running Linux 3.8.13 with arm processor Jim Chen
RE: asyn driver problem running Linux 3.8.13 with arm processor Mark Rivers
RE: asyn driver problem running Linux 3.8.13 with arm processor Jim Chen
Prev: RE: motorRecord on linux-arm Mark Rivers
Next: Re: motorRecord on linux-arm Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: asyn driver problem running Linux 3.8.13 with arm processor Jim Chen
Next: RE: asyn driver problem running Linux 3.8.13 with arm processor Jim Chen
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
