1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Area Detector IOC: how to change MAXSIZE X and Y?
To: "'Mark Rivers'" <[email protected]>, Tech-talk <[email protected]>
Date: Tue, 11 Feb 2014 16:45:23 +0000
Thank you,
I am using Procilica, and it did the job.
Oksana
Sent: Tuesday, February 11, 2014 11:21 AM
To: Ivashkevych, Oksana; Tech-talk
Hi Oksana,
I am not quite sure what you are asking.  You don’t need to change MaxSizeX and MaxSizeY.  You just need to set the readout region and binning for the mode you want to use.   You will then get whatever maximum frame rate the camera is capable of with that configuration.  This is done all the time with the AVT cameras.
Are you using the areaDetector Prosilica driver or the Aravis driver?  Either can be used to control this camera.
From: [email protected] [mailto:[email protected]] On Behalf Of Ivashkevych, Oksana
Sent: Tuesday, February 11, 2014 10:10 AM
To: Tech-talk
Subject: Area Detector IOC: how to change MAXSIZE X and Y?
I have a GigE camera GC655 and Area Detector IOC running on Debian. At its standard configuration 659X493 camera can perform at 90 fps. And I am achieving this through epics IOC.
This camera has another mode. When you reduce the area to 320x240 it is performing at 164 fps. The AVT screen shot is attached. Many cameras have this mode.
How I can change/set max size in epics IOC to 320x240 to achieve this performance?
Perhaps someone has already done this.
I have tried changing it through AVT software, assigning new configuration to different ConfigFileIdexes, however, every time I start IOC, it resets it to default max size. Size is _RBV record only.
Thank you,
Oksana
Area Detector IOC: how to change MAXSIZE X and Y? Ivashkevych, Oksana
RE: Area Detector IOC: how to change MAXSIZE X and Y? Mark Rivers
Prev: RE: Area Detector IOC: how to change MAXSIZE X and Y? Mark Rivers
Next: Re: Binding an IOC to a single network interface Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Channel Access Link Antonio Borondo
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
