1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Binary record that recover its value after changed
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 13 Feb 2014 16:02:49 +0100
Last not least,
there is online documentation (in this case the page about the bo record in the Record Reference Manual at https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Binary_Output), which has its issues and certainly does not answer all questions, but ... quite a few. ;-)
Cheers,
~Ralph
On 13.02.2014 15:54, Rolf Keitel wrote:
Antonio,
set the HIGH field of the binary output record to the number of seconds you want it to stay at 1.
- rolf -
On 2/13/2014 6:45 AM, Antonio Borondo wrote:
I have defined a binary output for a command in EPICS which always is 0. If the user change the value to 1 (by a CSS/BOY interface) it must change to 0 again after a few seconds. How can I do that?
Thank you very much,
Antonio Borondo
Binary record that recover its value after changed Antonio Borondo
Re: Binary record that recover its value after changed Rolf Keitel
Prev: Re: Binary record that recover its value after changed Rolf Keitel
Next: MSI macro setting in substitutions file Westfall, Michael D
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Binary record that recover its value after changed Antonio Borondo
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
