<[email protected]> writes:
> In recent times, I use caLab and LabVIEW to transfer and acquire
> data in EPICS in the same network segment. After the client run
> for a day or a bit longer, the program will stop and could not
> refresh at all. After some trials, I found that the “caLabPut.vi”
> function works well but the “caLabGet.vi” doesn’t. And if I stop
> the carepeater.exe process in Task Manager and restart the client
> program, the vi seems to work well again. I don’t know why and how
> to solve the problem?
Did you check the memory usage of your program? If it is growing, there
might be a memory leak.
Jani Hakala
- Re: using caLab and LabVIEW to a chunk of data in LAN Carsten Winkler
- using caLab and LabVIEW to a chunk of data in LAN ccc1989
RE: Binary record that recover its value after changed Antonio Borondo
<2014>
2025
2026
<2014>
2025
2026
