1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: using caLab and LabVIEW to a chunk of data in LAN
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Mon, 17 Feb 2014 08:12:10 +0100
Hi Chaocai,
I'm the developer of CA Lab. We have a lot of applications which are
using CA Lab here at BESSY. Many of them are running months and longer
without any problem. Therefore it's not easy to tell you how to solve
your problem. Could you send me an extract of your VI which demonstrates
the problem? Then I can surely help you.
Carsten Winkler
Am 14.02.2014 08:16, schrieb Jani Hakala:
> <[email protected]> writes:
>>     In recent times, I use caLab and LabVIEW to transfer and acquire
>>     data in EPICS in the same network segment. After the client run
>>     for a day or a bit longer, the program will stop and could not
>>     refresh at all. After some trials, I found that the “caLabPut.vi”
>>     function works well but the “caLabGet.vi” doesn’t. And if I stop
>>     the carepeater.exe process in Task Manager and restart the client
>>     program, the vi seems to work well again. I don’t know why and how
>>     to solve the problem?
> Did you check the memory usage of your program? If it is growing, there
> might be a memory leak.
> Jani Hakala
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
using caLab and LabVIEW to a chunk of data in LAN ccc1989
Re: using caLab and LabVIEW to a chunk of data in LAN Jani Hakala
Prev: RE: areaDetector driver for Point Grey FlyCapture2 SDK? Mark Rivers
Next: EPICS/ModbusTCP communication with Rockwell Micro 850 PLC faure
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: using caLab and LabVIEW to a chunk of data in LAN Jani Hakala
Next: Job Announcement: Control System Software Architect at European Spallation Source Suzanne Gysin
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
