Hi there.
We use a linux VME kernel driver and API from GE-Fanuc. We have created
a "software shim" that recreates the VxWorks API in terms of the Linux
driver. This was developed using EPICS release 3.14.8.2 and has worked
well up to and including 3.14.11. However release 3.14.12 introduced a
"devLib
cleanup" which changed the API and broke our code. We now want to
update our code to a sustainable model.
How should we proceed?
BTW We require devlib2 for building support for the MRF event
generator/receiver which will also run on Linux. How does devlib V1
relate to the additional functions defined in devlib2?
Jane
On 02/14/2014 02:34 PM, Rod Nussbaumer wrote:
On 02/14/2014 01:49 PM, Jane Richards wrote:
Hi Rod,
For your input...
Jane
On 02/14/2014 12:45 PM, graham waters wrote:
Hi Jane
Before I send anythingtech-talk I should run it by you first.
Graham
Subject: linux vme support
The below statement is similar to those which I consistently find
troubling; the blurring of functionality at the kernel module level,
and the EPICS level. The wording needs to make it clear what level is
referred where it says 'and mimic vxWorks functions calls'. I assume
we mean that the vxWorks mimicry is done in some level of our local
EPICS code. This should be made clear, to avoid any confusion by
readers. Is there some level of code that we add, replace, or modify
that is part of EPICS base &/or devLibX? Specify.
We use a linux vme kernel driver and API from GE-Fanuc and mimic
vxWorks functions calls in order to use the osi functionality of
devlib.
This was developed using EPICS release 3.14.8.2 and has worked well up
to and including 3.14.11. However release 3.14.12 introduced a "devLib
cleanup" which removed a structure that I rely on - "devLibVirtualOS". I
realize that my Linux support was not registered with the EPICS base
developers - mea culpa. I now want to update my code to a sustainable
model.
My questions are
1) What was the rational behind the changes and how should I proceeed.
2) How does devlib V1 relate to the additional functions defined in
devlib2-2.4 which we downloaded from sourceforge
generator/receiver which I will also be porting to Linux.
Jane Richards
Controls Group Leader, TRIUMF
4004 Wesbrook Mall, Vancouver, BC V6T 2A3
Phone: (604) 222-1047 (ext 7693)
Fax: (604) 222-1074
- Re: Vme support in devLib for Linux Andrew Johnson
- Re: Vme support in devLib for Linux Dirk Zimoch
RE: record processing time Mark Rivers
control knobs to a new control system Jack
<2014>
2025
2026
ThorLabs BSC203 support? Goetze, Kurt A.
<2014>
2025
2026
