Hi Jane,
On 02/14/2014 05:55 PM, Jane Richards wrote:
> We use a linux VME kernel driver and API from GE-Fanuc. We have created
> a "software shim" that recreates the VxWorks API in terms of the Linux
> driver. This was developed using EPICS release 3.14.8.2 and has worked
> well up to and including 3.14.11. However release 3.14.12 introduced a
> "devLib
> cleanup" which changed the API and broke our code. We now want to
> update our code to a sustainable model.
> How should we proceed?
Hopefully the changes we made should not require too much in the way of
modifications to your implementation. The Release Notes entry explains
most of the changes, and my guess is that you may only have to include
the new devLibVMEImpl.h header to be able to compile against 3.14.12.
There are other changes which may be worth doing, renaming your virtual
OS table from pdevLibVirtualOS to pdevLibVME for example, but there is a
macro defined in the new Impl.h file which does that for you.
> BTW We require devlib2 for building support for the MRF event
> generator/receiver which will also run on Linux. How does devlib V1
> relate to the additional functions defined in devlib2?
The best person to answer that question is Michael Davidsaver, who is
responsible for both implementations and can also comment on future
plans. He has been busy recently with the NSLS-2 work ramping up though,
so I don't know how soon or how extensively he'll be able to respond.
HTH,
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Re: Vme support in devLib for Linux Michael Davidsaver
- Re: Vme support in devLib for Linux Jane Richards
- Vme support in devLib for Linux Jane Richards
Re: record processing time Andrew Johnson
RE: control knobs to a new control system Emmanuel Mayssat
<2014>
2025
2026
<2014>
2025
2026
