Hi Mark,
That was a good suggestion, as my rmem_default was set to 128k.
Unfortunately, that helps, but not enough.
I can run one camera in RGB1 at 17+fps,
but if 2 cameras are in RGB1 I can't get them to go faster than 2 fps.
I've only tried one host machine w/ 2 cameras so far, w/ the other 2 off,
but trying to go any faster gets into the same
problem w/ dropped packets and the fps goes down instead of up.
I also tried setting rmem_default to 2MB instead of 1MB but no significant
improvement. rmem_max is 16MB.
If I put one camera into bayer mode, I can run both at 18fps, or I can run
both at 18fps. I'll do some more testing tomorrow.
- Bruce
P.S. I'm running setuid root w/ jumbo buffers
On 2/17/2014 8:30 PM, Mark Rivers wrote:
Hi Bruce,
This really sounds a lot like the problem of the Linux Ethernet network buffers being too small. We've seen similar problems where one camera would work fine, but then when trying to run multiple cameras on the same interface there would be lots of dropped packets and the rates go way down.
This is from a message I sent on 4/22/2013 to the folks at LCLS who were having similar problems:
Folks,
I think I have solved the problem of dropping frames on the Prosilica cameras on Linux. The solution is simply to increase the value of the parameters net.core.rmem_max and net.core.rmem_default to 1048576.
First, see what the current value of the parameters are on your system:
sudo sysctl -a | grep net.core.rmem
On my system the values were the following:
net.core.rmem_max = 131071
net.core.rmem_default = 126976
So they are about 128 KB. I then increased them to 1MB as suggested by the Point Grey article:
http://www.ptgrey.com/support/kb/index.asp?a=4&q=354
Colorado:areaDetector/iocBoot/iocPS3>sudo sysctl -w net.core.rmem_max=1048576 net.core.rmem_default=1048576
Colorado:areaDetector/iocBoot/iocPS3>sudo sysctl -a | grep net.core.rmem
net.core.rmem_max = 1048576
net.core.rmem_default = 1048576
Once I made those changes I could run 3 cameras on our Linux system with 4 cores and a single GigE interface and lose no frames at 5 frames/sec with both JPEG and Statistics plugins running. At 10 frames/sec I lost only 5 frames/3000, or less than 0.2%. Under these conditions all 4 cores are 100% busy, and I was previously losing 50% of the frames. You were losing 15% of the frames.
Please give this a try ASAP and let me know if it fixes it for you as well.
This is the link to a tech-talk message that also discusses this:
http://www.aps.anl.gov/epics/tech-talk/2013/msg00787.php
Sent: Monday, February 17, 2014 8:07 PM
To: Mark Rivers
Cc: Nelson, Silke; [email protected]
Subject: Bayer vs RGB1 performance for Prosilica cameras
Hi Mark,
I've been digging into a problem we've been having with some of
our Prosilica cameras not being able to sustain a decent frame rate
when read via areaDetector.
Most of our gigE cameras work great, but I traced the problem to our
color cameras, which are Manta G146C, 1388x1038 w/ 4MB image.
Best case we're getting 7-8fps on these, and when more than one was
in use on an experiment, we couldn't run them reliably at more than 1fps
unless we put each on it's own local ethernet adapter. As long as each
camera has it's own adapter, they can run 7-8fps. My initial theory was
that we were getting network packet failures as the camera is sending
all the data via UDP packets.
By chance, one ended up in free run and Bayer mode, and I found it
running nearly 18hz. I setup a test w/ 4 IOC's split across 2 RHEL5 hosts, each
reading one Manta G146C cameras via our switch, and can run all 4 at 18hz.
Setting one to RGB1 causes it to drop to a few fps, w/ lots of packet errors
and dropped frames.
I tried making the exe owned by root w/ setuid, and I can toggle either camera
between Bayer and RGB1 and both maintain 17+fps, but if I put both in RGB1,
I start getting tons of packet errors and the fps plummets on both cameras.
Have you seen any issues w/ RGB1 vs Bayer on these cameras?
Is that something that would be handled in the areaDetector code, or
should I be contacting Allied Vision?
Thanks!
- Bruce
- RE: Bayer vs RGB1 performance for Prosilica cameras Mark Rivers
- Bayer vs RGB1 performance for Prosilica cameras Bruce Hill
VS: control knobs to a new control system Koponen Jukka
epics base with MinGW-w64 Wang Xiaoqiang
<2014>
2025
2026
<2014>
2025
2026
