1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: VS: control knobs to a new control system
To: Emmanuel Mayssat <[email protected]>, "Konrad, Martin" <[email protected]>, Jack <[email protected]>, EPICS mailing list <[email protected]>
Cc: Thomas Schösser <[email protected]>
Date: Tue, 18 Feb 2014 07:36:08 +0000
in JYU in our IGISOL research facility we are testing Griffin PowerMate (http://store.griffintechnology.com/powermate) in Windows environment. PowerMate is a quite cheap and low effort commercial knob solution, and it's extremely easy to bring into play e.g. with LabVIEW since it can be set up to send keyboard commands/events.
The cons are at least that with PowerMate you don't have the feeling of turning speed because it doesn't make any clicks or similar when turned. Other side of the coin, though, is that from the PowerMate driver you can adjust the sensitivity of the knob individually for every program that is set to receive the commands from the knob. More user experience will be gathered in the future.
Cheers,
Jukka Koponen
Graduate student
Department of Physics
University of Jyväskylä
PB 35 (YFL)
FIN-40014 University of Jyväskylä
Finland
Lähettäjä: [email protected] [[email protected]] käyttäjän Emmanuel Mayssat [[email protected]] puolesta
Lähetetty: 18. helmikuuta 2014 0:39
Vastaanottaja: Konrad, Martin; Jack; EPICS mailing list
Kopio: Thomas Schösser
Aihe: RE: control knobs to a new control system
> -use two of them at the same time, one for each hand (using a pointing
> device for X/Y is not the same as it can be hard to move the axes
> separately)
Interesting point.
With a computer only 1 widget has the focus at a time.
With hardware, you can control several independent knobs concurrently
Indeed, when you drive a car, you interface with the wheel, accelerator, stick shift, brakes, iphone, and wife quickly after minor training.
E
control knobs to a new control system Jack
Re: control knobs to a new control system Konrad, Martin
RE: control knobs to a new control system Emmanuel Mayssat
Prev: Re: control knobs to a new control system Jack
Next: Re: Bayer vs RGB1 performance for Prosilica cameras Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: control knobs to a new control system Emmanuel Mayssat
Next: RE: control knobs to a new control system Andreas Luedeke
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
