Hi Mauro,
at PSI we use a "knob-box", where you can assign an EPICS PV to a
physical wheel. Four of this wheels are in one box.
A touch screen above these wheels show the actual value of the PV and
allows you to control the step size of the wheel, set the former
set-point (old value), or to type a numeric value to a device.
Unfortunately the box is an in-house design, you cannot buy it
off-the-shelf. Rob Emery's solution sounds more promising for you.
A knob-box is very nice if you want to fine tune a couple of devices
simultaneously without looking at the screen or the keyboard.
But I agree with Emmanuel that you can achieve the same thing with
keyboard control. MEDM or QtDM supports in addition to sliders the so
calls "wheelswitch". In QtDM this can be controlled by the keyboard, as
well as a slider can. It may needs a little bid of initial effort to
create key-bindings that work for you, since switching from one device
to the other is not yet supported. But it is maybe less effort then the
long term support of the control knobs hardware.
Cheers
Andreas
Re: Vme support in devLib for Linux Michael Davidsaver
RE: control knobs to a new control system Emmanuel Mayssat
<2014>
2025
2026
VS: control knobs to a new control system Koponen Jukka
RE: areaDetector driver for Point Grey FlyCapture2 SDK? Mark Rivers
<2014>
2025
2026
ANJ, 17 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
