1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Waveform record I/O interrupt. asyn
To: "techtalk " <[email protected]>
Date: 21 Feb 2014 18:35:02 -0000
Hello,
     I am facing problem in I/O Interrupt for waveform record in the asyn.  If the value of waveform record change very fast then some of the samples missing or same sample repeat twice even if  before p_interruptInt32Array->callback () function the value is scanned properly by driver. But i think the read value is pushed to the callback but it is not handle that much fast in the callback.
I checked the code for interruptCallbackInput   in devAsynXXXArray.h.
In devAsynXXXArray.c  dbScanUnlock has been used before  scanIoRequest().   Can it create problem for repeating same value?
My assumption is as dbScanUnlock  and before scanIoRequest() execute, value change and second time triggers interrupt. This result same value for both interrupts.
I checked interrupt callback code  in devAsynInt32.c where  epicsMutexUnlock has been used after scanIoRequest().
Thank you
Vishnu
Get your own FREE website, FREE domain & FREE mobile app with Company email.
Know More >
RE: Waveform record I/O interrupt. asyn Dalesio, Leo
RE: Waveform record I/O interrupt. asyn Mark Rivers
Prev: Re: Epics/Raspberry Pi data acquisition Steve Shoaf
Next: RE: Epics/Raspberry Pi data acquisition Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Running Linux commands inside 'st.cmd' Andrew Johnson
Next: RE: Waveform record I/O interrupt. asyn Dalesio, Leo
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
