1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Waveform record I/O interrupt. asyn
To: Vishnu Patel <[email protected]>, "techtalk " <[email protected]>
Date: Fri, 21 Feb 2014 22:51:35 +0000
Yes – this is true. Some options:
There are some options
You could write something in the driver that allocates memory on initialization and puts the arrays in there – point the device support at the buffered data.
Disable the digitizer until it is rearmed
Look are areaDetector for processing the arrays under the EPICS database
Channel Access also does not buffer arrays – it only queues up the pointer to the array. If you are reusing the same buffer (as the waveform record does) it may also be overwritten if the client is not taking the data fast enough.
We are working on ways to better support very large arrays in EPICS V4 – these must be done for us over the next 12 months – but only pieces are done now.
Bob
From: [email protected] [mailto:[email protected]] On Behalf Of Vishnu Patel
Sent: Friday, February 21, 2014 12:35 PM
To: techtalk
Subject: Waveform record I/O interrupt. asyn
Hello,
     I am facing problem in I/O Interrupt for waveform record in the asyn.  If the value of waveform record change very fast then some of the samples missing or same sample repeat twice even if  before p_interruptInt32Array->callback () function the value is scanned properly by driver. But i think the read value is pushed to the callback but it is not handle that much fast in the callback.
I checked the code for interruptCallbackInput   in devAsynXXXArray.h.
In devAsynXXXArray.c  dbScanUnlock has been used before  scanIoRequest().   Can it create problem for repeating same value?
My assumption is as dbScanUnlock  and before scanIoRequest() execute, value change and second time triggers interrupt. This result same value for both interrupts.
I checked interrupt callback code  in devAsynInt32.c where  epicsMutexUnlock has been used after scanIoRequest().
Thank you
Vishnu
Get your own FREE website, FREE domain & FREE mobile app with Company email.
Know More >
RE: Waveform record I/O interrupt. asyn Hill, Jeff
Waveform record I/O interrupt. asyn Vishnu Patel
Prev: RE: Epics/Raspberry Pi data acquisition Hill, Jeff
Next: RE: Waveform record I/O interrupt. asyn Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Waveform record I/O interrupt. asyn Vishnu Patel
Next: RE: Waveform record I/O interrupt. asyn Hill, Jeff
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
