1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Fw: Re: Error in building epics base-3.15.0.1 on windows XP (32 bit) using mingw
To: [email protected]
Date: Wed, 26 Feb 2014 10:33:48 +0530
-----Forwarded by Anindya Roy/B/vecc on 02/26/2014 10:33AM -----
Date: 02/26/2014 10:32AM
Subject: Re: Error in building epics base-3.15.0.1 on windows XP (32 bit) using mingw
(See attached file: build_log.txt)
Dear Andrew
Thanks for your reply, however base-3.15.0.1 is available for download at epics site at the following link and it was released on August 1, 2012.
http://www.aps.anl.gov/epics/download/base/index.php
One more thing, I have built base-3.15.0.1 for windows using cross compiler on linux platform (as suggested in Release note) and as far as example ioc is concerned, it is running on Windows XP (32 bit).
Regarding Epics base-3.14.12.3, the build error looks similar, the build log is attached for you. Kindly help me out, actually we are using epics for quite a long time (base-3.14.8.2), now we feel to update our version.
Thanks again
Anindya
अ निंद्य रॉय / Anindya Roy
वैज्ञ��निक अधिकारी / Scientific Officer
कंप्यूटर एवं सूचना वर��ग / Computer and Informatics Group
परिवर्ती उर्जा साइक्लोट्रॉन केंद्र / Variable Energy Cyclotron Centre
परमाणु उर्जा विभाग / Department of Atomic Energy
भारत सरकार / Government of India
1/ए एफ विधान नगर / 1/AF Bidhan Nagar
को��काता - 700064 , भा��त / Kolkata - 700064, India
फोन / Ph (O): +91-033-23184558
फैक्स / Fax (O): +91-033-23346871
-----Andrew Johnson <[email protected]> wrote: -----
To: Anindya Roy <[email protected]>, <[email protected]>
Date: 02/25/2014 09:26PM
On 02/25/2014 02:27 AM, Anindya Roy wrote:
> The build log file for epics base-3.15.0.1 using mingw and GNU Make 3.81
> on Windows X 32 bit is attached.
The 3.15.0.1 release was for EPICS developers only and is coming up for
2 years old, so it is very out of date compared to the development
branch in our version control system. There will be a 3.15.1 release for
application and operational use at some point in the future, but until
then please use the 3.14.12 series for application development.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
make -C ./configure install
make[1]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/configure'
perl ../src/tools/makeMakefile.pl O.win32-x86-mingw ../..
perl -MExtUtils::Command -e mkpath O.Common
make -C O.win32-x86-mingw -f ../Makefile TOP=../.. T_A=win32-x86-mingw install
make[2]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/configure/O.win32-x86-mingw'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/configure/O.win32-x86-mingw'
make[1]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/configure'
make -C ./src install
make[1]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src'
make -C ./tools install
make[2]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/tools'
perl ../../src/tools/makeMakefile.pl O.win32-x86-mingw ../../..
make -C O.win32-x86-mingw -f ../Makefile TOP=../../.. T_A=win32-x86-mingw install
make[3]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/tools/O.win32-x86-mingw'
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm"
mkdir ../../../lib
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm"
"Installing script ../../../bin/win32-x86-mingw/convertRelease.pl"
mkdir ../../../bin
mkdir ../../../bin/win32-x86-mingw
"Installing script ../../../bin/win32-x86-mingw/cvsclean.pl"
"Installing script ../../../bin/win32-x86-mingw/dos2unix.pl"
"Installing script ../../../bin/win32-x86-mingw/expandVars.pl"
"Installing script ../../../bin/win32-x86-mingw/filterWarnings.pl"
"Installing script ../../../bin/win32-x86-mingw/fullPathName.pl"
"Installing script ../../../bin/win32-x86-mingw/installEpics.pl"
"Installing script ../../../bin/win32-x86-mingw/makeIncludeDbd.pl"
"Installing script ../../../bin/win32-x86-mingw/makeMakefile.pl"
"Installing script ../../../bin/win32-x86-mingw/makeTestfile.pl"
"Installing script ../../../bin/win32-x86-mingw/mkmf.pl"
"Installing script ../../../bin/win32-x86-mingw/munch.pl"
"Installing script ../../../bin/win32-x86-mingw/replaceVAR.pl"
"Installing script ../../../bin/win32-x86-mingw/useManifestTool.pl"
make[3]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/tools/O.win32-x86-mingw'
make[2]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/tools'
make -C ./makeBaseApp install
make[2]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/makeBaseApp'
perl ../../bin/win32-x86-mingw/makeMakefile.pl O.win32-x86-mingw ../../..
make[3]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/makeBaseApp/O.win32-x86-mingw'
"Installing script ../../../bin/win32-x86-mingw/makeBaseApp.pl"
"Installing ../../../templates/makeBaseApp/top/Makefile"
mkdir ../../../templates
mkdir ../../../templates/makeBaseApp
mkdir ../../../templates/makeBaseApp/top
"Installing ../../../templates/makeBaseApp/top/configure/CONFIG"
mkdir ../../../templates/makeBaseApp/top/configure
"Installing ../../../templates/makeBaseApp/top/configure/CONFIG_SITE"
"Installing ../../../templates/makeBaseApp/top/configure/Makefile"
"Installing ../../../templates/makeBaseApp/top/configure/RELEASE"
"Installing ../../../templates/makeBaseApp/top/configure/RULES"
"Installing ../../../templates/makeBaseApp/top/configure/RULES.ioc"
"Installing ../../../templates/makeBaseApp/top/configure/RULES_DIRS"
"Installing ../../../templates/makeBaseApp/top/configure/RULES_TOP"
"Installing ../../../templates/makeBaseApp/top/supportApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/supportApp
"Installing ../../../templates/makeBaseApp/top/supportApp/Db/Makefile"
mkdir ../../../templates/makeBaseApp/top/supportApp/Db
"Installing ../../../templates/makeBaseApp/top/supportApp/src/Makefile"
mkdir ../../../templates/makeBaseApp/top/supportApp/src
"Installing ../../../templates/makeBaseApp/top/supportApp/src/_APPNAME_.dbd"
"Installing ../../../templates/makeBaseApp/top/iocApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/iocApp
"Installing ../../../templates/makeBaseApp/top/iocApp/Db/Makefile"
mkdir ../../../templates/makeBaseApp/top/iocApp/Db
"Installing ../../../templates/makeBaseApp/top/iocApp/src/Makefile"
mkdir ../../../templates/makeBaseApp/top/iocApp/src
"Installing ../../../templates/makeBaseApp/top/iocApp/src/_APPNAME_Main.cpp"
"Installing ../../../templates/makeBaseApp/top/exampleApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/exampleApp
"Installing ../../../templates/makeBaseApp/top/exampleApp/Db/Makefile"
mkdir ../../../templates/makeBaseApp/top/exampleApp/Db
"Installing ../../../templates/makeBaseApp/top/exampleApp/Db/dbExample1.db"
"Installing ../../../templates/makeBaseApp/top/exampleApp/Db/dbExample2.db"
"Installing ../../../templates/makeBaseApp/top/exampleApp/Db/dbSubExample.db"
"Installing ../../../templates/makeBaseApp/top/exampleApp/Db/user.substitutions"
"Installing ../../../templates/makeBaseApp/top/exampleApp/Db/userHost.substitutions"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/Makefile"
mkdir ../../../templates/makeBaseApp/top/exampleApp/src
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.dbd"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.c"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/devXxxSoft.c"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/xxxSupport.dbd"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/sncExample.stt"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/sncProgram.st"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/sncExample.dbd"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.c"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.dbd"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Main.cpp"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.c"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.dbd"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/initTrace.c"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/initTrace.dbd"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/Makefile"
mkdir ../../../templates/makeBaseApp/top/exampleBoot
"Installing ../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@vxWorks"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@RTEMS"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@Common"
mkdir ../../../templates/makeBaseApp/top/exampleBoot/ioc
"Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@vxWorks"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@win32"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@Common"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@vxWorks"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@RTEMS"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/README@Common"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/README@vxWorks"
"Installing ../../../templates/makeBaseApp/top/caClientApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/caClientApp
"Installing ../../../templates/makeBaseApp/top/caClientApp/caExample.c"
"Installing ../../../templates/makeBaseApp/top/caClientApp/caMonitor.c"
"Installing ../../../templates/makeBaseApp/top/caServerApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/caServerApp
"Installing ../../../templates/makeBaseApp/top/caServerApp/README"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exAsyncPV.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exChannel.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exPV.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exScalarPV.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exServer.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exServer.h"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exVectorPV.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/main.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/test.adl"
"Installing ../../../templates/makeBaseApp/top/caServerApp/vxEntry.cc"
"Installing ../../../templates/makeBaseApp/top/iocBoot/Makefile"
mkdir ../../../templates/makeBaseApp/top/iocBoot
"Installing ../../../templates/makeBaseApp/top/iocBoot/nfsCommands@vxWorks"
"Installing ../../../templates/makeBaseApp/top/iocBoot/nfsCommands@RTEMS"
"Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common"
mkdir ../../../templates/makeBaseApp/top/iocBoot/ioc
"Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@vxWorks"
"Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@win32"
"Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Common"
"Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Cross"
"Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks"
"Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS"
make[3]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/makeBaseApp/O.win32-x86-mingw'
make[2]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/makeBaseApp'
make -C ./makeBaseExt install
make[2]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/makeBaseExt'
make[3]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/makeBaseExt/O.win32-x86-mingw'
"Installing script ../../../bin/win32-x86-mingw/makeBaseExt.pl"
"Installing ../../../templates/makeBaseExt/top/Makefile"
mkdir ../../../templates/makeBaseExt
mkdir ../../../templates/makeBaseExt/top
"Installing ../../../templates/makeBaseExt/top/README"
"Installing ../../../templates/makeBaseExt/top/configure/CONFIG"
mkdir ../../../templates/makeBaseExt/top/configure
"Installing ../../../templates/makeBaseExt/top/configure/CONFIG_SITE"
"Installing ../../../templates/makeBaseExt/top/configure/Makefile"
"Installing ../../../templates/makeBaseExt/top/configure/RELEASE"
"Installing ../../../templates/makeBaseExt/top/configure/RULES"
"Installing ../../../templates/makeBaseExt/top/configure/RULES_DIRS"
"Installing ../../../templates/makeBaseExt/top/configure/RULES_TOP"
"Installing ../../../templates/makeBaseExt/top/configure/RULES_PYTHON"
"Installing ../../../templates/makeBaseExt/top/configure/RULES_IDL"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG.linux-x86.linux-386"
mkdir ../../../templates/makeBaseExt/top/configure/os
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG.win32-x86-borland.win32-x86-borland"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.Common.Common"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc-gnu.aix-ppc-gnu"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc.aix-ppc"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx86.darwin-ppcx86"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc-gnu.hpux-parisc-gnu"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc.hpux-parisc"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.interix-x86.interix-x86"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-borland.linux-x86-borland"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-athlon"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc.solaris-sparc"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64.solaris-sparc64"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-debug.solaris-x86-debug"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.solaris-x86"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86_64.solaris-x86_64"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-borland.win32-x86-borland"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-cygwin.win32-x86-cygwin"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.win32-x86"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.windows-x64.windows-x64"
"Installing ../../../templates/makeBaseExt/top/src/Makefile"
mkdir ../../../templates/makeBaseExt/top/src
"Installing ../../../templates/makeBaseExt/top/exampleExt/Makefile"
mkdir ../../../templates/makeBaseExt/top/exampleExt
"Installing ../../../templates/makeBaseExt/top/exampleExt/caExample.c"
"Installing ../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM"
"Installing ../../../templates/makeBaseExt/top/simpleExt/Makefile"
mkdir ../../../templates/makeBaseExt/top/simpleExt
make[3]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/makeBaseExt/O.win32-x86-mingw'
make[2]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/makeBaseExt'
make -C ./libCom install
make[2]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/libCom'
make[3]: Entering directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/libCom/O.win32-x86-mingw'
perl ../../../src/libCom/misc/makeEpicsVersion.pl ../../../configure/CONFIG
_BASE_VERSION ../O.Common
Building epicsVersion.h from ../../../configure/CONFIG_BASE_VERSION
Found EPICS Version 3.14.12.3
"Installing generated generic include file ../../../include/epicsVersion.h"
mkdir ../../../include
"Installing generic include file ../../../include/bucketLib.h"
"Installing generic include file ../../../include/epicsRingPointer.h"
"Installing generic include file ../../../include/epicsRingBytes.h"
"Installing generic include file ../../../include/postfix.h"
"Installing generic include file ../../../include/cvtFast.h"
"Installing generic include file ../../../include/epicsAlgorithm.h"
"Installing generic include file ../../../include/epicsExcept.h"
"Installing generic include file ../../../include/epicsMemory.h"
"Installing generic include file ../../../include/resourceLib.h"
"Installing generic include file ../../../include/tsDLList.h"
"Installing generic include file ../../../include/tsSLList.h"
"Installing generic include file ../../../include/tsMinMax.h"
"Installing generic include file ../../../include/tsBTree.h"
"Installing generic include file ../../../include/tsFreeList.h"
"Installing generic include file ../../../include/epicsSingleton.h"
"Installing generic include file ../../../include/epicsGuard.h"
"Installing generic include file ../../../include/epicsOnce.h"
"Installing generic include file ../../../include/dbmf.h"
"Installing generic include file ../../../include/ellLib.h"
"Installing generic include file ../../../include/envDefs.h"
"Installing generic include file ../../../include/epicsPrint.h"
"Installing generic include file ../../../include/errMdef.h"
"Installing generic include file ../../../include/errSymTbl.h"
"Installing generic include file ../../../include/errlog.h"
"Installing generic include file ../../../include/error.h"
"Installing generic include file ../../../include/fdManager.h"
"Installing generic include file ../../../include/fdmgr.h"
"Installing generic include file ../../../include/freeList.h"
"Installing generic include file ../../../include/gpHash.h"
"Installing generic include file ../../../include/iocsh.h"
"Installing generic include file ../../../include/registry.h"
"Installing generic include file ../../../include/libComRegister.h"
"Installing generic include file ../../../include/iocLog.h"
"Installing generic include file ../../../include/logClient.h"
"Installing generic include file ../../../include/macLib.h"
"Installing generic include file ../../../include/adjustment.h"
"Installing generic include file ../../../include/cantProceed.h"
"Installing generic include file ../../../include/dbDefs.h"
"Installing generic include file ../../../include/epicsConvert.h"
"Installing generic include file ../../../include/epicsExit.h"
"Installing generic include file ../../../include/epicsStdlib.h"
"Installing generic include file ../../../include/epicsString.h"
"Installing generic include file ../../../include/epicsTypes.h"
"Installing generic include file ../../../include/shareLib.h"
"Installing generic include file ../../../include/epicsExport.h"
"Installing generic include file ../../../include/unixFileName.h"
"Installing generic include file ../../../include/locationException.h"
"Installing generic include file ../../../include/ipAddrToAsciiAsynchronous.h"
"Installing generic include file ../../../include/compilerDependencies.h"
"Installing generic include file ../../../include/epicsUnitTest.h"
"Installing generic include file ../../../include/testMain.h"
"Installing generic include file ../../../include/os/WIN32/osiFileName.h"
mkdir ../../../include/os
mkdir ../../../include/os/WIN32
"Installing generic include file ../../../include/osiSock.h"
"Installing generic include file ../../../include/os/WIN32/osdSock.h"
"Installing generic include file ../../../include/epicsInterrupt.h"
"Installing os dependent include file ../../../include/os/WIN32/osdInterrupt.h"
"Installing generic include file ../../../include/epicsMutex.h"
"Installing generic include file ../../../include/os/WIN32/osdMutex.h"
"Installing generic include file ../../../include/epicsEvent.h"
"Installing generic include file ../../../include/os/WIN32/osdEvent.h"
"Installing generic include file ../../../include/os/WIN32/epicsMath.h"
"Installing os dependent include file ../../../include/os/WIN32/osdMessageQueue.h"
"Installing generic include file ../../../include/os/WIN32/osdStrtod.h"
"Installing generic include file ../../../include/epicsAssert.h"
"Installing generic include file ../../../include/epicsFindSymbol.h"
"Installing generic include file ../../../include/osiPoolStatus.h"
"Installing generic include file ../../../include/os/WIN32/osdPoolStatus.h"
"Installing generic include file ../../../include/os/WIN32/osdThread.h"
"Installing generic include file ../../../include/epicsThread.h"
"Installing generic include file ../../../include/epicsTime.h"
"Installing generic include file ../../../include/epicsGeneralTime.h"
"Installing generic include file ../../../include/os/WIN32/osdTime.h"
"Installing generic include file ../../../include/generalTimeSup.h"
"Installing generic include file ../../../include/osiClockTime.h"
"Installing generic include file ../../../include/epicsSignal.h"
"Installing generic include file ../../../include/osiProcess.h"
"Installing generic include file ../../../include/os/WIN32/osiUnistd.h"
"Installing generic include file ../../../include/osiWireFormat.h"
"Installing os dependent include file ../../../include/os/WIN32/osdWireFormat.h"
"Installing generic include file ../../../include/os/WIN32/osdWireConfig.h"
"Installing generic include file ../../../include/epicsEndian.h"
"Installing os dependent include file ../../../include/os/WIN32/epicsReadline.h"
"Installing generic include file ../../../include/epicsMessageQueue.h"
"Installing generic include file ../../../include/epicsStdio.h"
"Installing generic include file ../../../include/epicsStdioRedirect.h"
"Installing generic include file ../../../include/os/WIN32/epicsGetopt.h"
"Installing generic include file ../../../include/devLib.h"
"Installing generic include file ../../../include/devLibVME.h"
"Installing generic include file ../../../include/devLibVMEImpl.h"
"Installing os dependent include file ../../../include/os/WIN32/osdVME.h"
"Installing generic include file ../../../include/taskwd.h"
"Installing generic include file ../../../include/epicsTimer.h"
"Installing generic include file ../../../include/tsDefs.h"
windres -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../Com.rc Com.coff
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/bucketLib/bucketLib.c
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/ring/epicsRingPointer.cpp
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/ring/epicsRingBytes.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/calc/postfix.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/calc/calcPerform.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/cvtFast/cvtFast.c
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/cxxTemplates/resourceLib.cpp
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/cxxTemplates/epicsOnce.cpp
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/cxxTemplates/epicsSingletonMutex.cpp
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/dbmf/dbmf.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/ellLib/ellLib.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/env/envSubr.c
perl ../../../src/libCom/env/bldEnvData.pl ../../../configure
Generating envData.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        envData.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/error/errlog.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/error/errSymLib.c
perl ../../../src/libCom/error/makeStatTbl.pl  ../../../src/libCom/osi/devLib.h ../../../src/as/asLib.h ../../../src/db/dbAccessDefs.h ../../../src/dbStatic/devSup.h ../../../src/dbStatic/drvSup.h ../../../src/dbStatic/recSup.h ../../../src/dbStatic/dbStaticLib.h ../../../src/libCom/error/errMdef.h ../../../src/cas/generic/casdef.h ../../../src/gdd/gddAppFuncTable.h
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        errSymTbl.c
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/fdmgr/fdmgr.cpp
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/fdmgr/fdManager.cpp
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/freeList/freeListLib.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/gpHash/gpHashLib.c
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/iocsh/iocsh.cpp
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/iocsh/registry.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/iocsh/libComRegister.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/logClient/iocLog.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/logClient/logClient.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/macLib/macCore.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/macLib/macEnv.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/macLib/macUtil.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/misc/aToIPAddr.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/misc/adjustment.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/misc/cantProceed.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/misc/epicsConvert.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/misc/epicsExit.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/misc/epicsStdlib.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/misc/epicsString.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/misc/truncateFile.c
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/misc/epicsUnitTest.c
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/epicsThread.cpp
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/epicsMutex.cpp
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/epicsEvent.cpp
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/epicsTime.cpp
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/epicsMessageQueue.cpp
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/epicsMath.cpp
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/epicsGeneralTime.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/osiClockTime.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/os/WIN32/osdSock.c
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/os/WIN32/osdSockAddrReuse.cpp
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/osiSock.c
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/os/WIN32/systemCallIntMech.cpp
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/os/WIN32/epicsSocketConvertErrnoToString.cpp
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/os/default/osdAssert.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/os/default/osdFindSymbol.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/os/default/osdInterrupt.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/os/WIN32/osdPoolStatus.c
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/os/WIN32/osdSignal.cpp
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/os/default/osdEnv.c
gcc -c             -D_MINGW     -O3   -Wall   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_EPICS   -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/os/default/epicsReadline.c
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/epicsStdio.c
gcc -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/os/WIN32/osdStdio.c
gcc -c          -DDONT_USE_POSIX_THREAD_PRIORITY_SCHEDULING   -D
_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        ../../../src/libCom/osi/os/WIN32/osdThread.c
../../../src/libCom/osi/os/WIN32/osdThread.c:99:13: error: conflicting types for
 'DllMain'
 BOOL WINAPI DllMain (
In file included from f:\epics_base\mingw\include\windows.h:62:0,
                 from ../../../src/libCom/osi/os/WIN32/osdThread.c:29:
f:\epics_base\mingw\include\winbase.h:1051:13: note: previous declaration of 'Dl
lMain' was here
 BOOL WINAPI DllMain(HINSTANCE, DWORD, LPVOID);
make[3]: *** [osdThread.o] Error 1
make[2]: *** [install.win32-x86-mingw] Error 2
make[1]: *** [libCom.install] Error 2
make: *** [src.install] Error 2
make[3]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/libCom/O.win32-x86-mingw'
make[2]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src/libCom'
make[1]: Leaving directory `F:/epics_base/R-3-14-12/base-3.14.12.3/src'
Re: Error in building epics base-3.15.0.1 on windows XP (32 bit) using mingw Xiaoqiang Wang
Re: Error in building epics base-3.15.0.1 on windows XP (32 bit) using mingw Johnson, Andrew N.
Prev: Re: Fwd: epics base with MinGW-w64 Andrew Johnson
Next: Re: Error in building epics base-3.15.0.1 on windows XP (32 bit) using mingw Xiaoqiang Wang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Trouble with caget with denSnmp Nicoletta Petrella
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
