1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Error in building epics base-3.15.0.1 on windows XP (32 bit) using mingw
To: Anindya Roy <[email protected]>, Andrew Johnson <[email protected]>
Date: Wed, 26 Feb 2014 16:55:05 +0100
As the error suggests, the DllMain function in src/libCom/osi/os/WIN32/osdThread.c needs to be declared as
BOOL WINAPI DllMain (
    HINSTANCE hModule, DWORD dwReason, LPVOID lpReserved )
MSDN reference, http://msdn.microsoft.com/en-us/library/windows/desktop/ms682583(v=vs.85).aspx
Best
Xiaoqiang
On 26 Feb 2014, at 06:03, Anindya Roy <[email protected]> wrote:
> -----Forwarded by Anindya Roy/B/vecc on 02/26/2014 10:33AM -----
> To: Andrew Johnson <[email protected]>
> From: Anindya Roy/B/vecc
> Date: 02/26/2014 10:32AM
> (See attached file: build_log.txt)
> Dear Andrew
> Thanks for your reply, however base-3.15.0.1 is available for download at epics site at the following link and it was released on August 1, 2012.
> http://www.aps.anl.gov/epics/download/base/index.php
> One more thing, I have built base-3.15.0.1 for windows using cross compiler on linux platform (as suggested in Release note) and as far as example ioc is concerned, it is running on Windows XP (32 bit).
> Regarding Epics base-3.14.12.3, the build error looks similar, the build log is attached for you. Kindly help me out, actually we are using epics for quite a long time (base-3.14.8.2), now we feel to update our version.
> Thanks again
> Anindya
> अ निंद्य रॉय / Anindya Roy
> वैज्ञ� ��निक अधिकारी / Scientific Officer
> कंप्यूटर एवं सूचना वर� �ग / Computer and Informatics Group
> परिवर्ती उर्जा साइक्लोट्रॉन केंद्र / Variable Energy Cyclotron Centre
> परमाणु उर्जा विभाग / Department of Atomic Energy
> भारत सरकार / Government of India
> 1/ए एफ विधान नगर / 1/AF Bidhan Nagar
> को� �काता - 700064 , भा� �त / Kolkata - 700064, India
> फोन / Ph (O): +91-033-23184558
> फैक्स / Fax (O): +91-033-23346871
> -----Andrew Johnson <[email protected]> wrote: -----
> To: Anindya Roy <[email protected]>, <[email protected]>
> From: Andrew Johnson <[email protected]>
> Date: 02/25/2014 09:26PM
> Hi,
> On 02/25/2014 02:27 AM, Anindya Roy wrote:
> > The build log file for epics base-3.15.0.1 using mingw and GNU Make 3.81
> > on Windows X 32 bit is attached.
> The 3.15.0.1 release was for EPICS developers only and is coming up for
> 2 years old, so it is very out of date compared to the development
> branch in our version control system. There will be a 3.15.1 release for
> application and operational use at some point in the future, but until
> then please use the 3.14.12 series for application development.
> - Andrew
> Advertising may be described as the science of arresting the human
> intelligence long enough to get money from it. -- Stephen Leacock
> <build_log.txt>
Fw: Re: Error in building epics base-3.15.0.1 on windows XP (32 bit) using mingw Anindya Roy
Prev: Fw: Re: Error in building epics base-3.15.0.1 on windows XP (32 bit) using mingw Anindya Roy
Next: Re: Monitoring whether an IP device is connected or not J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Error in building epics base-3.15.0.1 on windows XP (32 bit) using mingw Xiaoqiang Wang
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
