1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Error in feching PV from CSS
To: [email protected], [email protected]
Date: Mon, 3 Mar 2014 14:32:51 +0000
Hi Swati,
That's because the text/value being displayed on a widget is not directly linked to a PV. From a script, you need to get get the PV itself and then use pv.setValue()
For further question on CSS, I suggest you use the CSS google group (https://groups.google.com/forum/#!forum/css-boy) is probably more appropriate for CSS specific questions
Hope that helps
David
Subject:Error in feching PV from CSS
To:EPICS mailing list <[email protected]>
Date: Mon, 3 Mar 2014 17:26:57 +0530
Hello All.
I am getting trouble to get value of attached PV from CSS widget. Here is my script:
importPackage(Packages.org.csstudio.opibuilder.scriptUtil);
var i = "Swati_Soni";
var value1 = display.getWidget("text1").getValue();
var value2 = display.getWidget("text2").getValue();
display.getWidget("t_display").setPropertyValue("text", i+"_"+value1+"_"+value2);
From this script I am able to concatenate the two value in textupdate "t_display" (widget shows the output), but the PV attached into it can not get updated with this concatenated value.
Is there any method so that the attached PV of "t-display"can be updated with "Swati_Soni_value1_value2".
text1 and text2 has=ai EPICS record ,whereas t_display has stringin record.
Thanks in advance,
Swati
Prev: Error in feching PV from CSS Swati Soni2
Next: RE: EPICS base-3.14.12.4 make Error Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Battling to start archive.engine on Postgresql db Ivan Kohler
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
