1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Error in feching PV from CSS
To: EPICS mailing list <[email protected]>
Date: Mon, 3 Mar 2014 17:26:57 +0530
Hello All.
I am getting trouble to get value of attached PV from CSS widget. Here is my script:
importPackage(Packages.org.csstudio.opibuilder.scriptUtil);
var i = "Swati_Soni";
var value1 = display.getWidget("text1").getValue();
var value2 = display.getWidget("text2").getValue();
display.getWidget("t_display").setPropertyValue("text", i+"_"+value1+"_"+value2);
From this script I am able to concatenate the two value in textupdate "t_display" (widget shows the output), but the PV attached into it can not get updated with this concatenated value.
Is there any method so that the attached PV of "t-display"can be updated with "Swati_Soni_value1_value2".
text1 and text2 has=ai EPICS record ,whereas t_display has stringin record.
Thanks in advance,
Swati
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
Prev: EPICS base-3.14.12.4 make Error zuo.jiao
Next: Re: Error in feching PV from CSS David Michel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS base-3.14.12.4 make Error Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
