1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Sequencer is not monitoring Pvs from another IOC
To: Ganesh Jangir <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 6 Mar 2014 14:40:11 +0000
In each IOC can you send the output of the command
epicsPrtEnvParams
From: [email protected] [[email protected]] on behalf of Ganesh Jangir [[email protected]]
Sent: Thursday, March 06, 2014 8:37 AM
To: [email protected]; [email protected]
Subject: Re: Sequencer is not monitoring Pvs from another IOC
Hi Pierrick, Benjamin
Thanks for the mail. I made an clean ioc using makeBaseApp.pl -t ioc <name> , makeBaseApp.pl -i -t ioc <name> . Added Db files and Sequencer files followed by successful make.
I am using
Epics base-3.14.12.3
Sequencer seq-2.1.16
OS: Linux Fedora 19  64bit
I am not using [X] procServ. Here is the environment variables.
#############declaring the EPICS environment LOCALLY#############################
export [X] EPICS_ROOT=/home/[X]ganesh/epics
export [X] EPICS_HOST_ARCH=[X]linux-x86_64
export [X] EPICS_BASE=$[X]EPICS_ROOT/[X]base-3.14.12.3
export [X] EPICS_EXTENSIONS=$[X]EPICS_ROOT/extensions
export [X] EPICS_CA_ADDR_LIST="192.168.8.2 192.168.8.3 192.168.8.4 192.168.8.5"
export [X] MOTIF_LIB=/[X]usr/[X]lib64/
export [X] SEQ=$[X]EPICS_ROOT/extensions/[X]seq-2.1.16
export PATH=/[X]sbin:/bin:/[X]usr/[X]sbin:/[X]usr/bin:$file:$[X]EPICS_ROOT/[X]base-3.14.12.3/bin/[X]linux-x86_64:/bin/[X]linux-x86_64
export [X] LD_LIBRARY_PATH=$[X]LD_LIBRARY_PATH:$[X]EPICS_BASE/lib/$[X]EPICS_HOST_ARCH:$[X]EPICS_EXTENSIONS/lib/$[X]EPICS_HOST_ARCH
-----[X]Pierrick [X] Hanlet wrote: -----
To: [X] Ganesh [X] Jangir <[email protected]>
Date: 03/06/2014 07:13PM
Subject: Re: [X] Sequencer is not monitoring [X] Pvs from another [X] IOC
Hi [X] Ganesh,
In order to get an answer from the experts, you will likely need to provide more information;
namely, version number of the software, the hardware configurations of the [X] IOCs, operating
system([X]s), etc.  For example, one [X] IOC may be in a [X] VME crate and another [X] IOC run from a
[X]linux [X] pc; then you would have to be certain to set the environment variables correctly,
particularly [X] EPICS_CA_ADDR_LIST.
Are you running these [X] IOCs from [X] procServ?  I'm asking because I have a similar issue.
Cheers,
[X]Pierrick
On 03/06/2014 01:23 PM, [X] Ganesh [X] Jangir wrote:
Dear All,
[X]Sequencer in one [X] IOC, is not able to monitor, [X] PV from another [X] IOC on the same network. However these [X] PVs are accessible by [X] caget and [X] camonitor on both machines.
[X]____Here is what I am doing.____________________________________________________
Machine 1, [X] IOC1.
[X]DB_1.db has
record(waveform, "[X]CMD_FIELD")
{    field([X]DESC, "command")
    field([X]NELM, 16000)
    field([X]FTVL, CHAR)
[X]SEQ1.stt
Updated above [X] PV successfully.
Machine 2 [X] IOC2
[X]SEQ2.stt has
char [X] CMD_[16000];
assign [X] CMD to "[X]CMD_FIELD";
monitor [X] CMD;
[X]evflag [X] cmdDFlag;
sync [X] CMD [X] cmdDFlag;
But not able to access the [X] PV. It works only when I am creating this [X] PV in [X] IOC2.
Please help.
Thanks and Regards
[X]Ganesh
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
[X]IIT/[X]Fermilab
+44-(0)1235-44-5550 ([X]RAL)
+1-630-840-5555 ([X]FNAL)
+1-312-567-5745 ([X]IIT)
+1-630-697-8758/+44-(0)79-48-860-197 (US/UK mobile)
Sequencer is not monitoring Pvs from another IOC Ganesh Jangir
Re: Sequencer is not monitoring Pvs from another IOC Ganesh Jangir
Prev: Re: CSS BEAST alarm hierarchy Kasemir, Kay
Next: Re: CSS BEAST alarm hierarchy Igor Kriznar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Sequencer is not monitoring Pvs from another IOC Ganesh Jangir
Next: RE: Sequencer is not monitoring Pvs from another IOC Ganesh Jangir
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
