1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Sequencer is not monitoring Pvs from another IOC
To: [email protected]
Cc: [email protected]
Date: Thu, 6 Mar 2014 23:10:03 +0530
Here is the output of seqChanShow and epicsPrtEnvParams for both IOC( both running on single machine).
No access/security is configured for PV. All are as per default.
epics> seqChanShow
No sequencer task specified.
Program Name        Thread ID           Thread Name         SS Name
c                   0x1962340           c                   ss1
                    0x7ff754036b50      c_1                 ss2
                    0x7ff754036db0      c_2                 ss3
__________________________________________________________________________________
epics> seqChanShow
cmc                 0x205e7d0             cmc                 ss1
                       0x7f1914036d90      cmc_1               ss2
                       0x7f1914036ff0        cmc_2               ss3
epics>
epics> epicsPrtEnvParams
EPICS_AR_PORT: 7002
EPICS_CAS_AUTO_BEACON_ADDR_LIST is undefined
EPICS_CAS_BEACON_ADDR_LIST is undefined
EPICS_CAS_BEACON_PERIOD is undefined
EPICS_CAS_BEACON_PORT is undefined
EPICS_CAS_IGNORE_ADDR_LIST is undefined
EPICS_CAS_INTF_ADDR_LIST is undefined
EPICS_CAS_SERVER_PORT is undefined
EPICS_CA_ADDR_LIST: 192.168.8.5 192.168.8.4 192.168.8.3 192.168.8.2 localhost
EPICS_CA_AUTO_ADDR_LIST: NO
EPICS_CA_BEACON_PERIOD: 15.0
EPICS_CA_CONN_TMO: 30.0
EPICS_CA_MAX_ARRAY_BYTES: 16665
EPICS_CA_MAX_SEARCH_PERIOD: 300.0
EPICS_CA_NAME_SERVERS is undefined
EPICS_CA_REPEATER_PORT: 5065
EPICS_CA_SERVER_PORT: 5064
EPICS_CMD_PROTO_PORT is undefined
EPICS_IOC_LOG_FILE_COMMAND is undefined
EPICS_IOC_LOG_FILE_LIMIT: 1000000
EPICS_IOC_LOG_FILE_NAME is undefined
EPICS_IOC_LOG_INET is undefined
EPICS_IOC_LOG_PORT: 7004
EPICS_TIMEZONE: CUS::360:031302:110602
EPICS_TS_NTP_INET is undefined
IOCSH_HISTSIZE: 50
IOCSH_PS1: epics>
epics>
Command epicsPrtEnvParam not found.
EPICS_AR_PORT: 7002
IOCSH_HISTSIZE: 50
IOCSH_PS1: epics>
epics>
Thanks and Regards
Ganesh
-----Mark Rivers wrote: -----
To: Ganesh Jangir <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: 03/06/2014 08:10PM
In each IOC can you send the output of the command
epicsPrtEnvParams
From: [email protected] [[email protected]] on behalf of Ganesh Jangir [[email protected]]
Sent: Thursday, March 06, 2014 8:37 AM
To: [email protected]; [email protected]
Subject: Re: Sequencer is not monitoring Pvs from another IOC
Hi Pierrick, Benjamin
Thanks for the mail. I made an clean ioc using makeBaseApp.pl -t ioc <name> , makeBaseApp.pl -i -t ioc <name> . Added Db files and Sequencer files followed by successful make.
I am using
Epics base-3.14.12.3
Sequencer seq-2.1.16
OS: Linux Fedora 19  64bit
I am not using [X] procServ. Here is the environment variables.
#############declaring the EPICS environment LOCALLY#############################
export [X] EPICS_ROOT=/home/[X]ganesh/epics
export [X] EPICS_HOST_ARCH=[X]linux-x86_64
export [X] EPICS_BASE=$[X]EPICS_ROOT/[X]base-3.14.12.3
export [X] EPICS_EXTENSIONS=$[X]EPICS_ROOT/extensions
export [X] EPICS_CA_ADDR_LIST="192.168.8.2 192.168.8.3 192.168.8.4 192.168.8.5"
export [X] MOTIF_LIB=/[X]usr/[X]lib64/
export [X] SEQ=$[X]EPICS_ROOT/extensions/[X]seq-2.1.16
export PATH=/[X]sbin:/bin:/[X]usr/[X]sbin:/[X]usr/bin:$file:$[X]EPICS_ROOT/[X]base-3.14.12.3/bin/[X]linux-x86_64:/bin/[X]linux-x86_64
export [X] LD_LIBRARY_PATH=$[X]LD_LIBRARY_PATH:$[X]EPICS_BASE/lib/$[X]EPICS_HOST_ARCH:$[X]EPICS_EXTENSIONS/lib/$[X]EPICS_HOST_ARCH
-----[X]Pierrick [X] Hanlet wrote: -----
To: [X] Ganesh [X] Jangir <[email protected]>
Date: 03/06/2014 07:13PM
Subject: Re: [X] Sequencer is not monitoring [X] Pvs from another [X] IOC
Hi [X] Ganesh,
In order to get an answer from the experts, you will likely need to provide more information;
namely, version number of the software, the hardware configurations of the [X] IOCs, operating
system([X]s), etc.  For example, one [X] IOC may be in a [X] VME crate and another [X] IOC run from a
[X]linux [X] pc; then you would have to be certain to set the environment variables correctly,
particularly [X] EPICS_CA_ADDR_LIST.
Are you running these [X] IOCs from [X] procServ?  I'm asking because I have a similar issue.
Cheers,
[X]Pierrick
On 03/06/2014 01:23 PM, [X] Ganesh [X] Jangir wrote:
Dear All,
[X]Sequencer in one [X] IOC, is not able to monitor, [X] PV from another [X] IOC on the same network. However these [X] PVs are accessible by [X] caget and [X] camonitor on both machines.
[X]____Here is what I am doing.____________________________________________________
Machine 1, [X] IOC1.
[X]DB_1.db has
record(waveform, "[X]CMD_FIELD")
{    field([X]DESC, "command")
    field([X]NELM, 16000)
    field([X]FTVL, CHAR)
[X]SEQ1.stt
Updated above [X] PV successfully.
Machine 2 [X] IOC2
[X]SEQ2.stt has
char [X] CMD_[16000];
assign [X] CMD to "[X]CMD_FIELD";
monitor [X] CMD;
[X]evflag [X] cmdDFlag;
sync [X] CMD [X] cmdDFlag;
But not able to access the [X] PV. It works only when I am creating this [X] PV in [X] IOC2.
Please help.
Thanks and Regards
[X]Ganesh
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
[X]IIT/[X]Fermilab
+44-(0)1235-44-5550 ([X]RAL)
+1-630-840-5555 ([X]FNAL)
+1-312-567-5745 ([X]IIT)
+1-630-697-8758/+44-(0)79-48-860-197 (US/UK mobile)
Re: Sequencer is not monitoring Pvs from another IOC Andrew Johnson
Re: Sequencer is not monitoring Pvs from another IOC Benjamin Franksen
RE: Sequencer is not monitoring Pvs from another IOC Mark Rivers
Sequencer is not monitoring Pvs from another IOC Ganesh Jangir
Re: Sequencer is not monitoring Pvs from another IOC Ganesh Jangir
Prev: Re: CSS BEAST alarm hierarchy Rolf Keitel
Next: Re: Sequencer is not monitoring Pvs from another IOC Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Sequencer is not monitoring Pvs from another IOC Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
