Quick follow up on this…
The problem turned out to be this line in /etc/rc.local:
chmod a+rw /dev/video*
It wasn't being run, even though the other lines in that file were. So if I run that command manually after a reboot, the camera works fine.
Nothing to do with RHEL6 kernel version number (I tried RHEL6.4 and RHEL6.5), or the fact that the server had a RAID card in it.
Cheers,
Matt
On Feb 4, 2014, at 10:21 AM, Mark Rivers <[email protected]> wrote:
> I communicated offline with Matt yesterday.
> At the APS we are running the Andor Neo with RHEL6 kernel 2.6.32-431.el6.x86_64. Matt is using 2.6.32-358.14.1.el6.x86_64.
> So both are 2.6.32, only differing slightly. We also were previously running an older build of RHEL6, though I am not sure exactly which kernel number.
> I suspect the problem is not the kernel version, but perhaps a conflict with another device or IRQ as Phil suggests.
> Mark
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of Phillip Sorensen
> Sent: Tuesday, February 04, 2014 8:05 AM
> To: [email protected]
> Subject: Re: Andor SDK3 Zyla
> Hello,
> We use the Neo on SL6 (a RHEL rebuild). We have not had problems with
> the software end, but we have had some issues with the CameraLink card
> under Linux. It seems to work in some slots, but not others. I think
> the drivers is sensitive to something like a shared IRQ.
> Phil Sorensen
> CHESS
> On 2/3/2014 2:22 PM, Pearson, Matthew R. wrote:
>> Hi,
>> We have a Andor Zyla camera, that we plan to control via the existing areaDetector driver for the Andor SDK3 library. However, we're finding that the SDK3 doesn't work on 64-bit RHEL6 (Kernel 2.6.32). I've not had the chance to test the EPICS support yet, as this is purely an Andor issue - their example programs fail to run correctly.
>> So I'm just wondering if anyone else has an Andor sCMOS camera, that uses SDK3, and has it working under Linux. If so, please could you let us know the distribution and kernel version number?
>> The camera example programs work on Windows 7 64-bit. So if we can't get it working on Linux that will be our fall back solution.
>> Cheers,
>> Matt
>> Data Acquisition and Control Engineer
>> Spallation Neutron Source
>> Oak Ridge National Lab
- Andor SDK3 Zyla Pearson, Matthew R.
- Re: Andor SDK3 Zyla Phillip Sorensen
- RE: Andor SDK3 Zyla Mark Rivers
Re: Problem with generating and installing OS specific header Andrew Johnson
Recommended practice for cvtRecord chain initialization Emmanuel Mayssat
<2014>
2025
2026
Epics with TCW122B-CM Nicoletta Petrella
<2014>
2025
2026
